On Mar 20, 4:12 am, minfitl...@yahoo.co.uk wrote:> On Mar 20, 9:52 am, "robert bristow-johnson" > > <r...@audioimagination.com> wrote: > > On Mar 19, 4:32 pm, "naebad" <minnae...@yahoo.co.uk> wrote: > > > > Cross correlation does not work well when estimating delays (unless > > > the signals are white). You need generalized cross correlation. > > > the signals need not be white, but what they need to be is broadbanded > > and *not* periodic, and then cross correlation works okay....> No, they need to be white for a good estimate of delay. There is not > space to discuss it all here. You need to look at Knapp and Carters > paper. > > Knapp, G.C. Carter, The generalized correlation method for estimation > of time delay, IEEE Trans. ASSP. 24 (4) (1976) 320-326. ...i don't have access to that paper (actually, that might be the one and only year i was an IEEE student member), but i have actually worked on this directly in the past and you CAN, using cross-correlation, get a very accurate and unambiguous measure of difference in arrival time between two microphone recieving the same sonic signal as long as it is not periodic (or quasi-periodic) and it is *sufficiently* broadbanded. it does not need to be broadbanded from DC all the way to Nyquist. and it need not be white. FYI, the application was about that of a TV reporter speaking into a microphone out in the field and some loud truck would drive by and drown out the reporter for a couple of seconds. so the idea was to use another microphone placed a meter or two away from the reporter (usually above his head out of view if you could) and use an NLMS to try to define a hypothetical filter between the ambient mic and the reporter mic. but because the interference sound could arrive at either of the mics first, we had to measure the difference in time of arrival and "center" the LMS FIR filter around that time. the LMS filter seemed to work like shit (didn't converge fast enough) but the measure of path length difference using cross-correlation worked very well when the common sound was loud, noisy, and not a tone. it certainly was not white, but it was somewhat broadbanded, but i would not say broadbanded up to Nyquist. the top two octaves probably had very little energy in them. r b-j
comparing audio signals to determine delay
Started by ●March 19, 2007
Reply by ●March 20, 20072007-03-20
> No, they need to be white for a good estimate of delay. There is not > space to discuss it all here. You need to look at Knapp and Carters > paper. > > Knapp, G.C. Carter, The generalized correlation method for estimation > of time delay, IEEE Trans. ASSP. 24 (4) (1976) 320-326. ...I briefly looked at the paper and I did not see any mention or proof of whiteness being a necassary condition to obtain a *good* unique estimate of the delay. In fact, it seems that the paper even recomends pre-filtering the signal at locations with high SNR, which would reduce the whiteness of the signal even futher... Offcourse, a high power white signal would be the optimal signal to esimate the delay because every sample is independent of each other and with unique values (ignoring quantitazation effects). But that does not mean that other signals can uniquely determine the lag between mics as well... Here is the abstract of the paper for those who are interested: *** Abstract A maximum likelihood (ML) estimator is developed for determining time delay between signals received at two spatially separated sensors in the presence of uncorrelated noise. This ML estimator can be realized as a pair of receiver prefilters followed by a cross correlator. The time argument at which the correlator achieves a maximum is the delay estimate. The ML estimator is compared with several other proposed processors of similar form. Under certain conditions the ML estimator is shown to be identical to one proposed by Hannan and Thomson [10] and MacDonald and Schultheiss [21]. Qualitatively, the role of the prefilters is to accentuate the signal passed to the correlator at frequencies for which the signal-to-noise (S/N) ratio is highest and, simultaneously, to suppress the noise power. The same type of prefiltering is provided by the generalized Eckart filter, which maximizes the S/N ratio of the correlator output. For low S/N ratio, the ML estimator is shown to be equivalent to Eckart prefiltering.
"Ikaro" <ikarosilva@hotmail.com> schreef in bericht news:1174414659.158897.36820@l77g2000hsb.googlegroups.com...>> No, they need to be white for a good estimate of delay. There is not >> space to discuss it all here. You need to look at Knapp and Carters >> paper. >> >> Knapp, G.C. Carter, The generalized correlation method for estimation >> of time delay, IEEE Trans. ASSP. 24 (4) (1976) 320-326. ... > > > I briefly looked at the paper and I did not see any mention or proof > of whiteness being a necassary condition to obtain a *good* unique > estimate of the delay. In fact, it seems that the paper even recomends > pre-filtering the signal at locations with high SNR, which would > reduce the whiteness of the signal even futher... > > Offcourse, a high power white signal would be the optimal signal to > esimate the delay because every sample is independent of each other > and with unique values (ignoring quantitazation effects). But that > does not mean that other signals can uniquely determine the lag > between mics as well... > > Here is the abstract of the paper for those who are interested: > > *** > Abstract > <cut> >I've found the paper and will take a closer look at it myself pretty soon. Some googling for the cross-correlation did turn up some nice pieces of information, which indeed makes it look like a suitable way to do what it's gotta do.. Of course, the sound of the surrounding will probably be far from periodic, so that won't be a problem.. Haven't got any response back with any information about the actual nodes, the university teachers are sooo busy these days... ahum... cough... Still, lots of thanks for all the advices, it already helped me greatly this far..
