Dear All, What is the best way to extract noise from data? I have an acoustic signal, which is fairly noisy (not sure of any of the noise parameters, just the usual stuff you get on a microphone). I ask because I�m trying to tidy up the spectrogram/fft, so that it 'look's pretty' and I reckon removing the noise from the original signal would be the way to go. I've not dealt with real data before, and have never thought about how best to get rid of noise. I considered using a threshold value but this seems rather brutish. What are the accepted practices for noise removal? Or do you have any pointers on literature/books I should be reading? Thanks for reading! matque
Noise Removal - any ideas???
Started by ●March 22, 2007
Reply by ●March 22, 20072007-03-22
On 22 Mar, 12:01, "matque" <michelle.mcgu...@eee.strath.ac.uk> wrote:> Dear All, > > What is the best way to extract noise from data? I have an acoustic > signal, which is fairly noisy (not sure of any of the noise parameters, > just the usual stuff you get on a microphone). > > I ask because I'm trying to tidy up the spectrogram/fft, so that it > 'look's pretty' and I reckon removing the noise from the original signal > would be the way to go.Nope.> I've not dealt with real data before, and have > never thought about how best to get rid of noise.The easiest noise to deal with, is the noise you never measure. Any extra effort spent on getting a good recording pays back with a factor 50+ in post processing.> I considered using a > threshold value but this seems rather brutish. What are the accepted > practices for noise removal? Or do you have any pointers on > literature/books I should be reading?The preface of Bendat & Piersol's "Random Data" (Wiley, 2000) mentins something like (written after memory) "the most valuable asset on any department dealing with real life measurements is skilled, experienced personnel." The kind of people who have seen it all befiore, done it all before, who is able to get a system up and running with blindfolds on. Maybe good advice for the future, not much help right now. The one thing you can do, is to filter the data. Apart from that, play with the settings in the spectrogram, like frame lengths, overlap, frequency range to display. Different settings can give very different visual impressions from the same data. Rune
matque a =E9crit :> Dear All, > > What is the best way to extract noise from data? I have an acoustic > signal, which is fairly noisy (not sure of any of the noise parameters, > just the usual stuff you get on a microphone). > > I ask because I'm trying to tidy up the spectrogram/fft, so that it > 'look's pretty' and I reckon removing the noise from the original signal > would be the way to go. I've not dealt with real data before, and have > never thought about how best to get rid of noise. I considered using a > threshold value but this seems rather brutish. What are the accepted > practices for noise removal? Or do you have any pointers on > literature/books I should be reading? > > Thanks for reading! > > matqueAdobe Audition (formerly CoolEdit) surely can help you. Here's how it removes noise. Basically, you record "silence" with your microphone, then you record what you want to record. You profile the "silence" (which really is the microphone's noise in its purest form) supposedly in the frequency domain, and then apparently the signal you want to filter is transformed into a frequency-time form (just like a spectrogram) and apparently an amount of each magnitude bin is substracted based on the pure noise's frequency profile and the signal is transformed back to time domain. Well this explanation is based on suppositions, but it seems to be how it works, and well you should just go ahead and use Adobe Audtion's noise reducer.
Thanks for the suggestions! I should have mentioned in my earlier post that I didn�t record the data myself. I�m working with existing data from another university and hence have to work with these noisy signals. This is also the reason why I have no information on the noise, other than I know it exists because I can see it on the plot. I�ve opted to just play around with the spectrogram parameters to improve the look of the plot. Any other suggestions?
Matque wrote:> I ask because I'm trying to tidy up the spectrogram/fft, so that it > 'look's pretty' and I reckon removing the noise from the original signal > would be the way to go.What don't you like about the spectrogram of your data?
Reply by ●March 23, 20072007-03-23
On Mar 22, 9:32 am, "matque" <michelle.mcgu...@eee.strath.ac.uk> wrote:> Thanks for the suggestions! I should have mentioned in my earlier post > that I didn't record the data myself. I'm working with existing data from > another university and hence have to work with these noisy signals. This > is also the reason why I have no information on the noise, other than I > know it exists because I can see it on the plot. > > I've opted to just play around with the spectrogram parameters to improve > the look of the plot. Any other suggestions?Matque, What you need is a non-parametric, blind adaptive scheme. Is the noise stationary with respect to the signal? If so, think about measuring the noise level between signal spurts, and develop a (S+N)/N ratio. Once developed, apply a gain that is inversely proportional to the SNR. BTW, it would work better if you decompose the signal first, apply the scheme, then recombine. Look up the general topic sub-band subtraction. Maurice Givens
