Hello, I am pretty new to the topic of DSP. However, I do have some practical experience with FFT and windowing. Now what I like to have is some explanation of how to implement a phase vocoder to create a (real-time) time compress/expand algoritm. Ofcourse I've been wandering around google for quite some time and I did see some already-made implementations for the Windows platform. But this does not do the trick. Every time I am using somebody else's lib I keep getting serious problems. This is obvious when you don't understand a byte of code in that lib. Using commercial ActiveX components that do what I want was not satisfactory (lincensing mumbo jumbo blah blah) therefore I want to write my own stuff. Is there anyone who can explain step by step how to build such an algoritm, without throwing lots of formulae? Or is there a website that can make it clear to me? Please note that I do have some (second-hand) experience with FFT. Thanks in advance! With kind regards, Rob Vermeulen Arbor AudioCommunications B.V. The Netherlands
Time Scaling using Phase Vocoder
Started by ●May 24, 2004
Reply by ●May 25, 20042004-05-25
Did you try my online tutorials at http://www.dspdimension.com/html/timepitch.html http://www.dspdimension.com/html/pshiftstft.html yet? That should get you started. The main page is http://www.dspdimension.com Regards, --smb
Hello Stephan, Yes, your page was one of the first I found. I translated your DFT a pied article into Dutch in order to explain to my fellow students how FFT works in theory. Good article! The information about pvoc got me as far as I am now. I know there's something like Phase Vocoding, I have a vague idea of how it works but I still haven't seen the light ;) I understand the FFT and windowing part. I also know that no modification of the magnitudes is necessary. But it stops at the point where I want to modify the phase part of the analysed fragment. I read a thesis from Florian Hammer about this subject but I do not have the mathematical background to completely understand the formulae. Also my English is not sufficient in order to understand quotes like "heterodyned phase increment". Anyway, I am very focussed on understanding the theory behind Phase Vocoders but it is the practical code implementation of the pvoc that has a bigger priority. So if someone could explain me step by step how to implement a time shifter using a Phase Vocoder, maybe it'll bring me closer to understand the theory. Don't get me wrong, I do not want somebody to give me complete source code of it. I definetely want to _know_ how it works. With kind regards, Rob Vermeulen "Stephan M. Bernsee" <stephan.bernsee@web.de> wrote in message news:38ab652c.0405242309.341a63b7@posting.google.com...> Did you try my online tutorials at > > http://www.dspdimension.com/html/timepitch.html > http://www.dspdimension.com/html/pshiftstft.html > > yet? That should get you started. The main page ishttp://www.dspdimension.com> > Regards, > --smb
I must have overlooked some of your explanations when I first read the web pages you pointed out, but now I've read your explanation about pitch shifting. This does explain a lot to me, especially the part about obtaining the true frequencies for each bin. Here comes my true question.... what next ? :-) I have got my magnitudes and true frequencies and now I want to time stretch it. That shouldn't be too difficult anymore... Can you give me a hint on how to achieve this? Best regards, Rob "Stephan M. Bernsee" <stephan.bernsee@web.de> wrote in message news:38ab652c.0405242309.341a63b7@posting.google.com...> Did you try my online tutorials at > > http://www.dspdimension.com/html/timepitch.html > http://www.dspdimension.com/html/pshiftstft.html > > yet? That should get you started. The main page ishttp://www.dspdimension.com> > Regards, > --smb
Hi Rob, I'm a bit short of time right now, so I can't really explain it to you in full, but I'm pretty sure the subject line will catch Richard Dobson's attention. He's a long time phase vocoder guru (as are some others here, like r b-j...;-) ), maybe he can get into more detail. The code on dspdimension works quite well btw. Airy Andr� has recently made a time/pitch manipulation plug in out of it that uses the pitch shifting procedure in combination with a sample rate conversion to produce time stretching, so you might want to try this. Regards, --smb
Reply by ●May 29, 20042004-05-29
Hello smb,>but I'm pretty sure the subject line will catch Richard > Dobson's attention. He's a long time phase vocoder guru (as are some > others here, like r b-j...;-) ), maybe he can get into more detail.Nope, haven't seen any responses yet.> The code on dspdimension works quite well btw. Airy Andr� has recently > made a time/pitch manipulation plug in out of it that uses the pitch > shifting procedure in combination with a sample rate conversion to > produce time stretching, so you might want to try this.Thanks for the hint! This actually works quite well. Only there are two drawbacks: - The (i)FFT algorithm in the pitchshifter isn't lightning fast :-) - My sample rate convertor makes horrible quality. What I do to convert the sample rate is to linear interpolate one buffer into another with the factor oldSR/newSR being equal to OldBufferSize/NewBufferSize. This seems to work well with a 50% and 200% conversion, but all other pecentages sound like an old cassette-player in a huge bathroom ;-) (metal/echo sound). Can you (ore anyone else) give a hint how to improve quality? Best regards, Rob
