On Apr 30, 10:39 am, Peter Nachtwey <p...@deltacompsys.com> wrote:> On Apr 30, 8:41 am, robert bristow-johnson <r...@audioimagination.com> > wrote: > > > > > On Apr 29, 1:12 am, Markus <iandj...@yahoo.com> wrote: > > > > On Apr 28, 11:36 am, robert bristow-johnson > > > > <r...@audioimagination.com> wrote: > > > > On Apr 27, 2:00 am, Markus <iandj...@yahoo.com> wrote: > > > > > > My problem is not dsp related, but the method is closely related to > > > > > methods in dsp, so I am hoping to get some help here. > > > > > > I am using the symmetric cubic convolution kernel ("Catmull-Rom > > > > > splines") to interpolate data over a limited range in a variable x. > > > > > For the interpolation I am using typically 10 nodes which are > > > > > equidistant in x. > > > > > Example: The interpolated function between nodes 4 and 5 is computed > > > > > based on the data points at nodes 3,4,5,6 > > > > > A nice property of the Catmull-Rom splines is that I get a continuous > > > > > 1st derivative everywhere. > > > > > sounds like Hermite polynomials. > > > > > > My question is now: how should I treat the ranges near the boundary? > > > > > With 10 nodes, how should I interpolate the data between node 9 and > > > > > 10? So far I am using linear interpolation here - but this is > > > > > conceptually ugly (and it's not precise, although the latter is not my > > > > > biggest problem since I want a _nice_ solution). > > > > > I am especially worried that in my current approach the interpolated > > > > > function has no continuous 1st derivative at node 9. > > > > > > Is there a solution, in which I could use e.g. a non-symmetric > > > > > convolution kernel to interpolate between nodes 9 and 10, based on the > > > > > nodes 8,9,10 or maybe 7,8,9,10 - in a way that I get a continuous 1st > > > > > derivative everywhere? > > > > > I have not found any discussion about the boundary-treatment in the > > > > > literature (and neither on the Google-wide web). In image processing > > > > > sometimes people mirror the image at the boundaries (i.e. they would > > > > > introduce a hypothetical 11th node for which the data value is set > > > > > equal to the data at the 9th node and then interpolate using the data > > > > > points at nodes 8,9,10,11) - but this would not work in my case. > > > > > > What I really want in the end, is the _kernel_ for the interpolation > > > > > at > > > > > the boundaries. > > > > > quadratic polynomial? now you have three constraints to satisfy > > > > instead of four. > > > > > r b-j > > > > Right: Quadratic Polynomials is what I need - but a special version: > > > one which has (at the left boundary) one point at the left, and two > > > points on the right side, > > > not quite, what you want is a quadratic polynomial that meets both > > points on the left and right (as you say) but not a second point > > further to the right, and the third constraint is match the derivative > > on the right to the derivative of the 3rd order polynomial one segment > > to the right. > > > r b-j > > > > i.e. a non-symmetric version. > > > I was no able to find a kernel for this. Do you know how such a kernel > > > looks like? > > > > Markus- Hide quoted text - > > > - Show quoted text -- Hide quoted text - > > > - Show quoted text - > > It is just a matter of sovling some simultaneous equations. Second > order interplation equations. > x(f)=(1-f)*x0+f*x1+0.5*(x2-2*x1+x0)*f*(1-f) for x0->x1 > x(f)=(1-f)*x1+f*x2+0.5*(x2-2*x1+x0)*f*(1-f) for x1->x2 > f is a fraction from 0 to 1. > > I don't see see why you are using a Catmull-Rom interpolator. I > generated an arbitrary 3rd order equation to generate 4 points at > equal intervals. The C-R couldn't even calculate the same > coefficients in my test equation. So what makes C-R so special if it > isn't as accurate as other methods? I would think that a 3rd order > inpolator should be able to reconstruct a third order polynomial > exactly from 4 points. > > Peter Nachtwey- Hide quoted text - > > - Show quoted text -Oops should be x(f)=(1-f)*x0+f*x1-0.5*(x2-2*x1+x0)*f*(1-f) for x0->x1 x(f)=(1-f)*x1+f*x2-0.5*(x2-2*x1+x0)*f*(1-f) for x1->x2 Peter Nachtwey
Interpolation w/ cubic convolution kernel - boundary treatment?
Started by ●April 27, 2007
Reply by ●April 30, 20072007-04-30
On Apr 30, 12:41 pm, Peter Nachtwey <p...@deltacompsys.com> wrote:> On Apr 30, 10:39 am, Peter Nachtwey <p...@deltacompsys.com> wrote: > > > > > On Apr 30, 8:41 am, robert bristow-johnson <r...@audioimagination.com> > > wrote: > > > > On Apr 29, 1:12 am, Markus <iandj...@yahoo.com> wrote: > > > > > On Apr 28, 11:36 am, robert bristow-johnson > > > > > <r...@audioimagination.com> wrote: > > > > > On Apr 27, 2:00 am, Markus <iandj...@yahoo.com> wrote: > > > > > > > My problem is not dsp related, but the method is closely related to > > > > > > methods in dsp, so I am hoping to get some help here. > > > > > > > I am using the symmetric cubic convolution kernel ("Catmull-Rom > > > > > > splines") to interpolate data over a limited range in a variable x. > > > > > > For the interpolation I am using typically 10 nodes which are > > > > > > equidistant in x. > > > > > > Example: The interpolated function between nodes 4 and 5 is computed > > > > > > based on the data points at nodes 3,4,5,6 > > > > > > A nice property of the Catmull-Rom splines is that I get a continuous > > > > > > 1st derivative everywhere. > > > > > > sounds like Hermite polynomials. > > > > > > > My question is now: how should I treat the ranges near the boundary? > > > > > > With 10 nodes, how should I interpolate the data between node 9 and > > > > > > 10? So far I am using linear interpolation here - but this is > > > > > > conceptually ugly (and it's not precise, although the latter is not my > > > > > > biggest problem since I want a _nice_ solution). > > > > > > I am especially worried that in my current approach the interpolated > > > > > > function has no continuous 1st derivative at node 9. > > > > > > > Is there a solution, in which I could use e.g. a non-symmetric > > > > > > convolution kernel to interpolate between nodes 9 and 10, based on the > > > > > > nodes 8,9,10 or maybe 7,8,9,10 - in a way that I get a continuous 1st > > > > > > derivative everywhere? > > > > > > I have not found any discussion about the boundary-treatment in the > > > > > > literature (and neither on the Google-wide web). In image processing > > > > > > sometimes people mirror the image at the boundaries (i.e. they would > > > > > > introduce a hypothetical 11th node for which the data value is set > > > > > > equal to the data at the 9th node and then interpolate using the data > > > > > > points at nodes 8,9,10,11) - but this would not work in my case. > > > > > > > What I really want in the end, is the _kernel_ for the interpolation > > > > > > at > > > > > > the boundaries. > > > > > > quadratic polynomial? now you have three constraints to satisfy > > > > > instead of four. > > > > > > r b-j > > > > > Right: Quadratic Polynomials is what I need - but a special version: > > > > one which has (at the left boundary) one point at the left, and two > > > > points on the right side, > > > > not quite, what you want is a quadratic polynomial that meets both > > > points on the left and right (as you say) but not a second point > > > further to the right, and the third constraint is match the derivative > > > on the right to the derivative of the 3rd order polynomial one segment > > > to the right. > > > > r b-j > > > > > i.e. a non-symmetric version. > > > > I was no able to find a kernel for this. Do you know how such a kernel > > > > looks like? > > > > > Markus- Hide quoted text - > > > > - Show quoted text -- Hide quoted text - > > > > - Show quoted text - > > > It is just a matter of sovling some simultaneous equations. Second > > order interplation equations. > > x(f)=(1-f)*x0+f*x1+0.5*(x2-2*x1+x0)*f*(1-f) for x0->x1 > > x(f)=(1-f)*x1+f*x2+0.5*(x2-2*x1+x0)*f*(1-f) for x1->x2 > > f is a fraction from 0 to 1. > > > I don't see see why you are using a Catmull-Rom interpolator. I > > generated an arbitrary 3rd order equation to generate 4 points at > > equal intervals. The C-R couldn't even calculate the same > > coefficients in my test equation. So what makes C-R so special if it > > isn't as accurate as other methods? I would think that a 3rd order > > inpolator should be able to reconstruct a third order polynomial > > exactly from 4 points. > > > Peter Nachtwey- Hide quoted text - > > > - Show quoted text - > > Oops should be > x(f)=(1-f)*x0+f*x1-0.5*(x2-2*x1+x0)*f*(1-f) for x0->x1 > x(f)=(1-f)*x1+f*x2-0.5*(x2-2*x1+x0)*f*(1-f) for x1->x2 > > Peter NachtweyI have now found what I was looking for! The following article describes in eq (5) a non-symmetric kernel for interplations in the region close to the boundary (and one half is identical to the Catmull-Rom kernel): G.-H. Cottet, P. Poncet, "Advances in direct numerical simulations of 3D wall-bounded flows by Vortex-in-Cell methods", J Comp. Phys 193 (2003) 136. The document is here: http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6WHY-49R5FDD-1&_user=3902909&_coverDate=01%2F01%2F2004&_rdoc=1&_fmt=&_orig=search&_sort=d&view=c&_acct=C000061728&_version=1&_urlVersion=0&_userid=3902909&md5=66c343753edd5ab1a12655ecff09c7a6 Thanks to everybody for your input, Markus
