Dear Sir, I am working on Acoustic Echo Cancellation. I have implemented both AEC without subbanding and AEC with subbanding in C+ +. For subbanding of AEC I used Polyphase IIR filter(with 70dB attenuation). AEC without subbanding is working fine. But in the outputs of AEC with subbanding there exists some slight disturbance(but echo is cancelling for all recorded audio files that are recorded through sound recorder and for some other audio files that I got from some application echo is not cancelling and this disturbance is continued). So I obsereved each function(ie., polyphase lowpass filter function, polyphase highpass filter function and the AEC operation function) output by printing each and every output value of functions in text files. In that I observed that where ever the highpass filter farend sample is negative(there by estimated echo is negative and hence and updated weights of that sample are negative) this distortion is occuring. So how to handle when updated weights are negative so that to get clear echo cancelled outputs. If any one knows information regarding this please reply to this mail. Thanks in advance. Regards, Aparna Ram.K.
Regarding Acoustic Echo Cancellation with subbanding
Started by ●April 27, 2007
