Hello, Assume you have 2 OFDM transmitters that are simultanously transmitting different data and the data is somehow coded (ie CDMA). After IFFT the ofdm symbol of each transmitter , X1 and X2, passes a freq. selective fading channel: Y = X1.G1 + X2.G2 + N My question is at the receiver, before or after the FFT, how to remove the effect G1 and G2 which are the fading coefficients. Thank you Shahin
OFDM Transmit diversity
Started by ●May 2, 2007
Reply by ●May 3, 20072007-05-03
On May 2, 5:35 pm, Shahin <gheitan...@gmail.com> wrote:> Hello, > > Assume you have 2 OFDM transmitters that are simultanously > transmitting different data and the data is somehow coded (ie CDMA). > After IFFT the ofdm symbol of each transmitter , X1 and X2, passes a > freq. selective fading channel: Y = X1.G1 + X2.G2 + N > > My question is at the receiver, before or after the FFT, how to remove > the effect G1 and G2 which are the fading coefficients. > > Thank you > ShahinHow about compute the inverse and convolve? Like zero-forcing equalization? Julius
On May 3, 2:21 pm, julius <juli...@gmail.com> wrote:> On May 2, 5:35 pm,Shahin<gheitan...@gmail.com> wrote: > > > Hello, > > > Assume you have 2OFDMtransmitters that are simultanously > > transmitting different data and the data is somehow coded (ie CDMA). > > After IFFT theofdmsymbol of each transmitter , X1 and X2, passes a > > freq. selective fading channel: Y = X1.G1 + X2.G2 + N > > > My question is at the receiver, before or after the FFT, how to remove > > the effect G1 and G2 which are the fading coefficients. > > > Thank you > > Shahin > > How about compute the inverse and convolve? Like zero-forcing > equalization? > > JuliusIf you mean the Inverse FFT and convolving with the known channel, computational wise it would be very complex. isn't it? Shahin
Reply by ●May 4, 20072007-05-04
On May 3, 12:16 pm, Shahin <gheitan...@gmail.com> wrote:> On May 3, 2:21 pm, julius <juli...@gmail.com> wrote: > > > > > On May 2, 5:35 pm,Shahin<gheitan...@gmail.com> wrote: > > > > Hello, > > > > Assume you have 2OFDMtransmitters that are simultanously > > > transmitting different data and the data is somehow coded (ie CDMA). > > > After IFFT theofdmsymbol of each transmitter , X1 and X2, passes a > > > freq. selective fading channel: Y = X1.G1 + X2.G2 + N > > > > My question is at the receiver, before or after the FFT, how to remove > > > the effect G1 and G2 which are the fading coefficients. > > > > Thank you > > > Shahin > > > How about compute the inverse and convolve? Like zero-forcing > > equalization? > > > Julius > > If you mean the Inverse FFT and convolving with the known channel, > computational wise it would be very complex. isn't it? > > ShahinSure, but it's not the only way to do channel estimation, right? Isn't that one of the big ideas with OFDM? Make the bins small enough such that the effective channel in each subchannel appears to be "flat" in the frequency domain. Then all you need to do zero-forcing equalization is just to divide by a (complex) number, per channel. Or, if your modulation is constant-modulus, do a rotation. If there's no clock offset in the system, then within each subband you have a multi-antenna system that appears to have been subjected to non-frequency selective distortion. What is it that you are asking again? Julius
