HELLO EVERYBODY! I'M TRYING TO COMPARE MC-CDMA AND MC-DS-CDMA USING SINGLE USER AND MULTI-USER DETECTION TECHNIQUES IN TERMS OF BIT ERROR RATE AND SPECTRAL EFFICIENCY IN A MOBILE COMMUNICATION USING MATLAB.THAT IS USING DIRECT SEQUENCE SPREAD SPECTRUM(TRANSMITTING THE CHIPS OVER SEVERAL SUB-CARRIERS),PERFORMING THE MULTI-CARRIER MODULATION AND DEMODULATION USING IFFT AND FFT OPERATIONS, SEPARATE THE USERS' SIGNALS IN THE CODE DOMAIN. BY THE WAY, I HAVE NO PROBLEM WITH THE THEORETICAL PARTS,CAN ANYONE HELP ME PLS? THANKS IN ADVANCE! BEST REGARDS!
MC-CDMA AND MC-DS-CDMA SIMULATION USING MATLAB
Started by ●May 22, 2007
Reply by ●May 22, 20072007-05-22
BULDO wrote:> HELLO EVERYBODY! > I'M TRYING TO COMPARE MC-CDMA AND MC-DS-CDMA USING SINGLE USER AND > MULTI-USER DETECTION TECHNIQUESARE YOU A WIDOW OF A FORMER NIGERIAN DICTATOR LOOKING FOR A WIRE TRANSFER OF ONE BILLION DOLLARS? SOMEHOW THEY ALWAYS WRITE MESSAGES IN ALL CAPS. VLV
BULDO wrote:> HELLO EVERYBODY! > I'M TRYING TO COMPARE MC-CDMA AND MC-DS-CDMA USING SINGLE USER AND > MULTI-USER DETECTION TECHNIQUES IN TERMS OF BIT ERROR RATE AND > SPECTRAL EFFICIENCY IN A MOBILE COMMUNICATION USING MATLAB.THAT IS > USING DIRECT SEQUENCE SPREAD SPECTRUM(TRANSMITTING THE CHIPS OVER > SEVERAL SUB-CARRIERS),PERFORMING THE MULTI-CARRIER MODULATION AND > DEMODULATION USING IFFT AND FFT OPERATIONS, SEPARATE THE USERS' > SIGNALS IN THE CODE DOMAIN. BY THE WAY, I HAVE NO PROBLEM WITH THE > THEORETICAL PARTS,CAN ANYONE HELP ME PLS? > THANKS IN ADVANCE! > BEST REGARDS!Why are you shouting? Is your shift-lock stuck on? Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Jerry Avins wrote:> BULDO wrote: >> HELLO EVERYBODY! > > Why are you shouting? Is your shift-lock stuck on?Posting from a KSR-33 :) Eric
Eric Brombaugh wrote:> Jerry Avins wrote: >> BULDO wrote: >>> HELLO EVERYBODY! >> >> Why are you shouting? Is your shift-lock stuck on? > > Posting from a KSR-33 > > :) > > EricI forgot about that. My ASR-33 had an extra-high type cylinder and two extra selector bars that gave it lower case. They were never marketed, but prototypes had been made and I got a hold of a set of spare parts. The whole A/KSR-33 project was kept secret from management until there were working models, and even then they were kept off the market in order not to compete with the ASR-35. When TTY Corp finally did decide to market a KSR-33, having it do lower case was simply unacceptable. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Jerry Avins wrote:> Eric Brombaugh wrote: >> Jerry Avins wrote: >>> BULDO wrote: >>>> HELLO EVERYBODY! >>> >>> Why are you shouting? Is your shift-lock stuck on? >> >> Posting from a KSR-33 >> >> :) >> >> Eric > > I forgot about that. My ASR-33 had an extra-high type cylinder and two > extra selector bars that gave it lower case. They were never marketed, > but prototypes had been made and I got a hold of a set of spare parts. > The whole A/KSR-33 project was kept secret from management until there > were working models, and even then they were kept off the market in > order not to compete with the ASR-35. When TTY Corp finally did decide > to market a KSR-33, having it do lower case was simply unacceptable.I once used a machine that looked just like an ASR33, but did upper and lower case. I don't know what it was called, though. Steve
Steve Underwood wrote: ...> I once used a machine that looked just like an ASR33, but did upper and > lower case. I don't know what it was called, though.A bootleg ASR-33. The original design before it was dumbed down. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Reply by ●May 24, 20072007-05-24
On May 22, 10:34 pm, Vladimir Vassilevsky <antispam_bo...@hotmail.com> wrote:> BULDO wrote: > > HELLO EVERYBODY! > > I'M TRYING TO COMPAREMC-CDMAAND MC-DS-CDMA USING SINGLE USER AND > > MULTI-USER DETECTION TECHNIQUES > > ARE YOU A WIDOW OF A FORMER NIGERIAN DICTATOR LOOKING FOR A WIRE > TRANSFER OF ONE BILLION DOLLARS? SOMEHOW THEY ALWAYS WRITE MESSAGES IN > ALL CAPS. > > VThanks for your "replies", but, i'm not from Nigeria.And besides that we are here to share knowledge, so, pls, reason before u post something. As i said in my post, i'm looking for help to simulate MC- CDMA/MC-DS-CDMA .
On May 24, 12:37 am, BULDO <mmagag...@gmail.com> wrote:> On May 22, 10:34 pm, Vladimir Vassilevsky <antispam_bo...@hotmail.com> > wrote:> BULDO wrote: > > > HELLO EVERYBODY! > > > I'M TRYING TO COMPAREMC-CDMAAND MC-DS-CDMA USING SINGLE USER AND > > > MULTI-USER DETECTION TECHNIQUES > > > ARE YOU A WIDOW OF A FORMER NIGERIAN DICTATOR LOOKING FOR A WIRE > > TRANSFER OF ONE BILLION DOLLARS? SOMEHOW THEY ALWAYS WRITE MESSAGES IN > > ALL CAPS. > > > V > > Thanks for your "replies", but, i'm not from Nigeria.And besides that > we are here to share knowledge, so, pls, reason before u post > something. As i said in my post, i'm looking for help to simulate MC- > CDMA/MC-DS-CDMA .Yes, but what help exactly do you need? You didn't say. Julius
