hi...i want to plot the STFT of a signal in matlab.....the signal is the return signal(echo)...from the rotating blades of a hovering helicopter....can...anyone...give me a method...to calculate STFT of this in matlab..i tried with the specgram..function....but..iam unable..to set it's parameters accordingly..so iam not getting the expected graph.....plz...help......
short term fourier tranform.....
Started by ●May 24, 2007
Reply by ●May 25, 20072007-05-25
On May 23, 10:45 pm, pks.n...@gmail.com wrote:> hi...i want to plot the STFT of a signal in matlab.....the signal is > the return signal(echo)...from the rotating blades of a hovering > helicopter....can...anyone...give me a method...to calculate STFT of > this in matlab..i tried with the specgram..function....but..iam > unable..to set it's parameters accordingly..so iam not getting the > expected graph.....plz...help......The crystal ball is fuzzy. How can anybody possible tell what the problem is if you don't give any meaningful parameter? What do you expect, and what do you have in your experiment?
Reply by ●May 28, 20072007-05-28
On 24 May, 05:45, pks.n...@gmail.com wrote:> hi...i want to plot the STFT of a signal in matlab.....the signal is > the return signal(echo)...from the rotating blades of a hovering > helicopter....can...anyone...give me a method...to calculate STFT of > this in matlab..i tried with the specgram..function....but..iam > unable..to set it's parameters accordingly..so iam not getting the > expected graph.....plz...help......The 'spectrogram' function in matlab is the correct function to use (it might be called 'specgram', though). Helicopter sounds have base frequencies around 10-20 Hz, and I would assume you need something like 0.5 -1 Hz bin width, maximum. These are numbers I guess based on previous experience with this sort of analysis; you will not find them anywhere. To get 1Hz bin width select your window length as round(1/Fs) where Fs is your sampling frequency. I would suggest somewhere between 50% and 75% overlap between successive frames. These are not fixed numbers, but a starting point for you to start playing around. Rune
