On May 25, 1:51 pm, "Vista" <a...@gmai.com> wrote:> "John Hadstate" <jh113...@hotmail.com> wrote in message > > news:1180094910.608568.259980@q75g2000hsh.googlegroups.com... > > > > > On May 25, 6:23 am, "Vista" <a...@gmai.com> wrote: > >> Hi all, > > >> I have two blocks of samples of signals. > > >> x0, ..., x_{n-1}, > > >> and > > >> y0, ..., y_{n-1}, > > >> where DFT[x]= y. > > >> Suppose I want to interpolate {x} by a upsampling rate of 2, how to do > >> that > >> by operating on the {y} sequence, assuming {x} is not given so we can > >> only > >> modify {y}? > > > Divide y into two equal pieces (each having n/2 samples). Insert n > > zeroes between the first half of y and the last half of y. IDFT the > > new sequence. > > >> How about decimating {x} by a downsampling rate of 2? > > > Divide y into 4 equal pieces (each having n/4 samples). Throw away > > the middle two pieces. IDFT the new sequence. > > Thanks John! Do you have any theorey/proof supporting your methods?it's correct (we are assuming a real signal to start with which corresponds to a complex conjugate symmetry in the other domain) and well known those middle two sections correspond to the high frequency half of the spectrum. the only thing different i would do is call it "N" instead of "n" and leave the small case letters for indices. r b-j
Interpolation and decimation in DFT...
Started by ●May 25, 2007
Reply by ●May 28, 20072007-05-28
