there are many applications use frequency multipliers to improve the deviation of narrowband FSK . i wonder is it suitable for boradband FSK? For example,the input signal should be 4FSK,and the frequencys is 67MHz/69MHz/71MHz/73MHz,the symbol rate is 10M .
Is frequency multipliers suitable for boradband FSK?
Started by ●June 8, 2007
Reply by ●June 8, 20072007-06-08
On Jun 8, 4:26 pm, "isgone" <isg...@hotmail.com> wrote:> there are many applications use frequency multipliers to improve the > deviation of narrowband FSK . i wonder is it suitable for boradband FSK? > For example,the input signal should be 4FSK,and the frequencys is > 67MHz/69MHz/71MHz/73MHz,the symbol rate is 10M .The modulation can be called "broadband FSK" only if h >> 1. That is not the case for your system, since the bandwidth of the modulating signal is larger than twice the deviation. John
Reply by ●June 11, 20072007-06-11
>The modulation can be called "broadband FSK" only if h >> 1. That is >not >the case for your system, since the bandwidth of the modulating signal >is larger than twice the deviation. > >John > >so it is a narrowband system ? but the bandwidth of the modulating signal is so large that it is hard to process . if i want a system which the input signal is 67MHz/69MHz/71MHz/73MHz 4FSK ,and the output signal is 335MHz/345MHz/355MHz/365MHz 4FSK , the symbol rate is aways 10M . is a x5 frequency multiplier suitable? because the symbol rate is high ,the frequencys change too fast , i afraid the frequency multiplier can't work .
