Can some one explain or point me to a paper with the proof of how the DCT matrix transformation Y=DCT(X) = AXA' (where A is the DCT transform matrix, X is the input data matrix, Y is the transformed data coeff's) A(u,v) = (1/N)^(1/2) for u =0 A(u,v) = (2/N)^(1/2) * cos(PI*(2v+1)*u/(2*N)) for u >0 is equivalent to the DCT def: N-1 N-1 Y(u,v) = alpha(u) * alpha (v) * sum sum X(x,y) * cos(PI*(2x+1)*u/ (2*N)) * cos(PI*(2y+1)*v/(2*N)) x y with alpha(u) = (1/N)^(1/2) for u =0 alpha(u) = (2/N)^(1/2) for u > 0 thanks in advance
how is the discrete cosine transform matrix transform equivalent to the standard dct definition (DCT-II)
Started by ●June 14, 2007
Reply by ●June 14, 20072007-06-14
wallge wrote:> Can some one explain or point me to a paper with the proof of how the > DCT matrix transformation > > Y=DCT(X) = AXA' (where A is the DCT transform matrix, X is the input > data matrix, Y is the transformed > data coeff's) > > A(u,v) = (1/N)^(1/2) for u =0 > A(u,v) = (2/N)^(1/2) * cos(PI*(2v+1)*u/(2*N)) for u >0 > > is equivalent to the DCT def: > > N-1 N-1 > Y(u,v) = alpha(u) * alpha (v) * sum sum X(x,y) * cos(PI*(2x+1)*u/ > (2*N)) * cos(PI*(2y+1)*v/(2*N)) > x y > > with alpha(u) = (1/N)^(1/2) for u =0 > alpha(u) = (2/N)^(1/2) for u > 0If you rewrite AXA' as (AX)A', and consider what's happening in each matrix multiplication (and also consider how a 2D DCT is formed from 1D DCTs), it should become apparent how the two are equivalent. -- Oli
