> You do know something about the frequency. It is higher than audio and > within the passband of your channel. You seem to say that it is of > constant frequency ans therefore only its presence is informative. Would > a bandpass filter do?I'd need to ensure the tone remained constant.. wouldn't the bandpass just tell me that "in this sample, a tone was present somewhere between x and y".. but not give me a "bucket" that I can track like I would with an FFT?
Burst tone detection of unknown frequency
Started by ●June 19, 2007
Reply by ●June 19, 20072007-06-19
Ron N. wrote: ...> Laughing. I used to answer my phone, saying something like: > "Hi, I'm actually home, you can talk to me instead of leaving a > message, BeeeeeeP! "; and hear the automated calling machines > hang up if I vocalized a clean enough beep tone.ROFL! Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Jay Fenton wrote:>> You do know something about the frequency. It is higher than audio and >> within the passband of your channel. You seem to say that it is of >> constant frequency ans therefore only its presence is informative. Would >> a bandpass filter do?Fenton didn't write that, I did.> I'd need to ensure the tone remained constant.. wouldn't the bandpass > just tell me that "in this sample, a tone was present somewhere > between > x and y".. but not give me a "bucket" that I can track like I would > with > an FFT?Do you have enough memory to save the samples that the filter output tells you are there, and enough time to do the occasional FFT when enough samples have been accumulated? That might be easier than feting all the time. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Jay Fenton wrote:>> You do know something about the frequency. It is higher than audio and >> within the passband of your channel. You seem to say that it is of >> constant frequency ans therefore only its presence is informative. Would >> a bandpass filter do?Fenton didn't write that, I did. :-)> I'd need to ensure the tone remained constant.. wouldn't the bandpass > just tell me that "in this sample, a tone was present somewhere > between > x and y".. but not give me a "bucket" that I can track like I would > with > an FFT?Do you have enough memory to save the samples that the filter output tells you are there, and enough time to do the occasional FFT when enough samples have been accumulated? That might be easier than FFTing all the time. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Ron N. wrote:> On Jun 19, 5:47 am, Jay Fenton <jay.fen...@gmail.com> wrote: >> I've been trying to find the most optimal algorithm to detect a >> sustained burst of >> tone at an unknown (but higher than speech) frequency in realtime, for >> use in >> voicemail detection (think long beep). I don't have much experience in >> the signal >> processing realms, and would appreciate any appropriate pointers. > > Laughing. I used to answer my phone, saying something like: > "Hi, I'm actually home, you can talk to me instead of leaving a > message, BeeeeeeP! "; and hear the automated calling machines > hang up if I vocalized a clean enough beep tone.Those machines don't generally listen for a tone. They use the heuristic that a long initial burst of speech is likely to be an automated system, and that a human answering will just say "hello" or their name. It breaks down when they call companies. The telephonist will generally give a longer announcement than a personal user, and the machines hang up. Steve
On Jun 19, 4:49 pm, Jay Fenton <jay.fen...@gmail.com> wrote:> On Jun 19, 7:44 pm, "Ron N." <rhnlo...@yahoo.com> wrote: > > > On Jun 19, 5:47 am, Jay Fenton <jay.fen...@gmail.com> wrote: > > > > I've been trying to find the most optimal algorithm to detect a > > > sustained burst of > > > tone at an unknown (but higher than speech) frequency in realtime, for > > > use in > > > voicemail detection (think long beep). I don't have much experience in > > > the signal > > > processing realms, and would appreciate any appropriate pointers. > > > Laughing. I used to answer my phone, saying something like: > > "Hi, I'm actually home, you can talk to me instead of leaving a > > message, BeeeeeeP! "; and hear the automated calling machines > > hang up if I vocalized a clean enough beep tone. > > Ahh, is that why I got a cold response from some.. I swear there's > not an automated calling machine in sight :) We're just not that > obnoxious.A more serious response ... IMO an easy way to detect the presence of the tone as well as its frequency is to use an FM discriminator and squelch circuit. First define a band of possible frequencies, Fc-W/2 to Fc+W/2. Mix the input with exp(-j*2*pi*Fc*n/Fs) and then apply LPFs with passband extending from 0 to W/2. You can decimate here too in order to save cycles later. Compute the instantaneous frequency of the complex LPF output z[n] as follows: f[n] = Fs*angle(z[n]*conj(z[n-1]))/(2*pi) (here Fs is the decimated sample rate). Apply f[n] to an IIR HPF. Take the absolute value of the HPF output and smooth the rectified noise with an IIR LPF. When no tone is present, you get a "large" DC value. When the tone comes on, the DC value plummets. Determine an empirical threshold to declare that the tone is present, and choose a larger threshold to subsequently declare that it went away. When the tone is present, the Fc + average(f[n]) estimates the input frequency. This method is tried and true, but one gotcha is that the detector requires some noise in the tone band. John
Ron N. wrote: (snip)> Laughing. I used to answer my phone, saying something like: > "Hi, I'm actually home, you can talk to me instead of leaving a > message, BeeeeeeP! "; and hear the automated calling machines > hang up if I vocalized a clean enough beep tone.I tried it the other way once, but it didn't work so well. I put a message on the answering machine something like: "Hello (pause) He isn't here right now, can I take a message?" With the pause long enough to ask to talk to someone. Then again, someone I used to know would answer the phone: "AMTRAK fares and information, ask about our new low fares to Europe." -- glen
