Hello, i'm looking for a tool or matlab function to convert head related transfer functions (impulse responses) into a minimum phase filter + corresponding allpass filter (or phase excess in the form of nr of samples for the interaural time delay). I would also be happy with a dataset that already has been converted. I've read through the minimum phase chapter in the oppenheim&schafer book, and i think i understand most of it, but have no idea how to let matlab do it to the HRTF data. I'm a comp science student with no background in dsp, only what ive learned myself the past year, and that isnt all that much. I just want to use minimum phase hrtf + correstponding ITD in a program I'm writing.
minimum phase HRTF
Started by ●June 22, 2007
Reply by ●June 22, 20072007-06-22
Be careful, if you convert your filters to minimum phase, the ITD for a given direction may be wrong, which is probably unwanted! Best regards, Andre Emile wrote:> Hello, > > i'm looking for a tool or matlab function to convert head related > transfer functions (impulse responses) into a minimum phase filter + > corresponding allpass filter (or phase excess in the form of nr of > samples for the interaural time delay). > I would also be happy with a dataset that already has been converted. > I've read through the minimum phase chapter in the oppenheim&schafer > book, and i think i understand most of it, but have no idea how to let > matlab do it to the HRTF data. > I'm a comp science student with no background in dsp, only what ive > learned myself the past year, and that isnt all that much. I just want > to use minimum phase hrtf + correstponding ITD in a program I'm writing.
Reply by ●July 24, 20072007-07-24
>Hello, > >i'm looking for a tool or matlab function to convert head related >transfer functions (impulse responses) into a minimum phase filter + >corresponding allpass filter (or phase excess in the form of nr of >samples for the interaural time delay). >I would also be happy with a dataset that already has been converted. >I've read through the minimum phase chapter in the oppenheim&schafer >book, and i think i understand most of it, but have no idea how to let >matlab do it to the HRTF data. >I'm a comp science student with no background in dsp, only what ive >learned myself the past year, and that isnt all that much. I just want >to use minimum phase hrtf + correstponding ITD in a program I'm writing. >Here is the expression for matlab using Hilbert Transform (Article by Malcolm Hawksford): c=fft(signal,fftsize); hmin=real(ifft(exp(conj(hilbert(log(abs(c))))),fftsize)); for the excess phase, just divide element to element in the fft domain, signal and hmin There is another direct way with matlab functios using the cepstrum: try cceps and rceps, its just the same. Be careful with phase and HRTF, you may loose critical info!
