Hello, I wanted to find out a way to check CPU load using an API in my C code. I use CCS 3.1 and DM642 DSP. The CPU load graph is available but to find out the exact value(if possible) using an API is required. The DSP/BIOS users guide mentions IDL_cpuLoad as an IDL object using IDL_F_busy function to calculate CPU load. I am not sure how to use this IDL_F_busy function to find CPU load. Could someone help me with this? Regards, APS
DM642 CPU Load Function
Started by ●July 4, 2007
