Hi all! Do you have any experience with an early-late gate timing? I've built one and observed strange behavior in weak S/N rate. Even though, I can observe acceptable scatterplot using Matlab function - demodulated data have a trend to loss time base (with still proper demodulation). Is it because of not proper phase recovery (5 to 10 degrees phase error) or maybe these 3 points in early -late timing method is to small and accidental noise component cause mentioned above timing errors? The problem does not exist in good S/N. I use 4 sample per symbol and 3 points of time analysis (early, prompt, late). Thank's in advance for any helpful advices or comments. Jarek
DPLL behavior with early-late gate timing method
Started by ●July 5, 2007
Reply by ●July 5, 20072007-07-05
On Jul 5, 2:56 am, jaromicha...@interia.pl wrote:> Hi all! > Do you have any experience with an early-late gate timing? I've built > one and observed strange behavior in weak S/N rate. Even though, I can > observe acceptable scatterplot using Matlab function - demodulated > data have a trend to loss time base (with still proper demodulation). > Is it because of not proper phase recovery (5 to 10 degrees phase > error) or maybe these 3 points in early -late timing method is to > small and accidental noise component cause mentioned above timing > errors? > > The problem does not exist in good S/N. > I use 4 sample per symbol and 3 points of time analysis (early, > prompt, late). > Thank's in advance for any helpful advices or comments. > JarekYou may not realize it, but what you have is a very discretized feedback loop. I would guess that your problem is that the gain of the loop or the bandwidth of the loop is not adjusted properly. Your question on the effect of residual phase recovery error is meaningless unless you say what your modulation is. Having 5-10 degrees of phase error is OK if you are using QPSK. It is not OK if you are using 256-QAM. Of course, there's a lot of details omitted. Julius
Reply by ●July 6, 20072007-07-06
On 5 Lip, 16:41, julius <juli...@gmail.com> wrote:> On Jul 5, 2:56 am, jaromicha...@interia.pl wrote: > > > Hi all! > > Do you have any experience with an early-late gate timing? I've built > > one and observed strange behavior in weak S/N rate. Even though, I can > > observe acceptable scatterplot using Matlab function - demodulated > > data have a trend to loss time base (with still proper demodulation). > > Is it because of not proper phase recovery (5 to 10 degrees phase > > error) or maybe these 3 points in early -late timing method is to > > small and accidental noise component cause mentioned above timing > > errors? > > > The problem does not exist in good S/N. > > I use 4 sample per symbol and 3 points of time analysis (early, > > prompt, late). > > Thank's in advance for any helpful advices or comments. > > Jarek > > You may not realize it, but what you have is a very discretized > feedback > loop. I would guess that your problem is that the gain of the loop or > the > bandwidth of the loop is not adjusted properly. > > Your question on the effect of residual phase recovery error is > meaningless > unless you say what your modulation is. Having 5-10 degrees of phase > error > is OK if you are using QPSK. It is not OK if you are using 256-QAM. > Of > course, there's a lot of details omitted. > > JuliusThank's for comment. There is QPSK of course. In fact, the problem is smaller when I introduce more samples per symbol. But loss of time base is still present in small S/N (now at about 5 dB less then earlier). I am starting to look for a program code error. Regards, Jarek
On Jul 6, 1:38 am, jaromicha...@interia.pl wrote:> > Thank's for comment. There is QPSK of course. In fact, the problem is > smaller when I introduce more samples per symbol. But loss of time > base is still present in small S/N (now at about 5 dB less then > earlier). I am starting to look for a program code error. > Regards, > JarekIf I understand you correctly, you may have fixed the problem when you used more samples per symbol because now effectively your feedback loop gain in reduced. If you want to really properly "design" your system, you have to examine the feedback loop part: there is a tradeoff between loop bandwidth (i.e. how fast it will converge) and noise immunity (by assuming that noise is white, and higher loop bandwidth means more noise is included in the output). I never want to assume what the modulation of a system that I do not know is. :^) Julius
