My goal is to implement a template structure on the DSK 6713. This template is to contain a structure for audio input/output, so that an algorithm can easily be fit into that template structure (for example a filter or a controller). To implement this a tutorial might be helpful, where step by step is explained how to send audio data to the line out/head phone jag and on the other way how to read from the audio line in/microphone jag (which c-functions are important etc.). Code examples might be also helpful. What I need first is a code that works with the audio I/O in the easiest way without special features and code optimization. I also have tested the swi-, pip- and tsk-audio examples, but I am missing an explication for the code and its configurations (DSP/BIOS etc.). I am looking forward to getting any help. Thanks a lot Johannes
TI-Board DSK 6713 for audio applications
Started by ●July 11, 2007
Reply by ●July 12, 20072007-07-12
On Jul 11, 12:48 pm, "JoSo" <johan...@kaesbach.de> wrote:> My goal is to implement a template structure on the DSK 6713. This > template is to contain a structure for audio input/output, so that an > algorithm can easily be fit into that template structure (for example a > filter or a controller). To implement this a tutorial might be helpful, > where step by step is explained how to send audio data to the line > out/head phone jag and on the other way how to read from the audio line > in/microphone jag (which c-functions are important etc.). Code examples > might be also helpful. What I need first is a code that works with the > audio I/O in the easiest way without special features and code > optimization. I also have tested the swi-, pip- and tsk-audio examples, > but I am missing an explication for the code and its configurations > (DSP/BIOS etc.). > > I am looking forward to getting any help. > > Thanks a lot > > JohannesHave a look at the books by Rulph Chassaing (Digital Signal Processing and Applications with the C6713 and C6416 DSK), Nasser Kehtarnavaz (Real-Time Digital Signal Processing based on the TMS320C6000) and Welch, Wright and Morrow (Real-Time Digital Signal Processing from MATLAB to C with the TMS320C6x DSK). Each of these does what you want, I think. Regards, Donald
On Jul 11, 4:48 am, "JoSo" <johan...@kaesbach.de> wrote:> My goal is to implement a template structure on the DSK 6713. This > template is to contain a structure for audio input/output, so that an > algorithm can easily be fit into that template structure (for example a > filter or a controller). To implement this a tutorial might be helpful, > where step by step is explained how to send audio data to the line > out/head phone jag and on the other way how to read from the audio line > in/microphone jag (which c-functions are important etc.). Code examples > might be also helpful. What I need first is a code that works with the > audio I/O in the easiest way without special features and code > optimization. I also have tested the swi-, pip- and tsk-audio examples, > but I am missing an explication for the code and its configurations > (DSP/BIOS etc.). > > I am looking forward to getting any help. > > Thanks a lot > > JohannesIt's been over a year since I've looked at this, but the best result I had was by modifying one of the example projects that came with the C6713 DSK. If I remember correctly, it was the DMA example. I tried the code from the Chassaing book's CD, and while it was useful as a reference I had trouble getting it to build.
