HI all My problem is : i have a signal x(n)(0<=n<=N), and i get y(k)=fft(x(n)),and 0<=k<=N; now , k=c*k',and c is a constant but c/=0; i want to get y(k') from y(k),and 0<=k'<=N too.someone said i can use sinc interpolation,what should i do? How to accomplish that?
about sinc interpolation
Started by ●July 20, 2007
Reply by ●July 22, 20072007-07-22
On Fri, 20 Jul 2007 09:32:21 -0500, p13dou wrote:> HI all > My problem is : i have a signal x(n)(0<=n<=N), and i get > > y(k)=fft(x(n)),and 0<=k<=N; now , k=c*k',and c is a constant but c/=0; i > > want to get y(k') from y(k),and 0<=k'<=N too.someone said i can use sinc > > interpolation,what should i do? How to accomplish that?Have you done web searches on the keywords "FFT" and "interpolation"? -- Tim Wescott Control systems and communications consulting http://www.wescottdesign.com Need to learn how to apply control theory in your embedded system? "Applied Control Theory for Embedded Systems" by Tim Wescott Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
Reply by ●July 23, 20072007-07-23
>On Fri, 20 Jul 2007 09:32:21 -0500, p13dou wrote: > >> HI all >> My problem is : i have a signal x(n)(0<=n<=N), and i get >> >> y(k)=fft(x(n)),and 0<=k<=N; now , k=c*k',and c is a constant but c/=0;i>> >> want to get y(k') from y(k),and 0<=k'<=N too.someone said i can usesinc>> >> interpolation,what should i do? How to accomplish that? > >Have you done web searches on the keywords "FFT" and "interpolation"? > >-- >Tim Wescott >Control systems and communications consulting >http://www.wescottdesign.com > >Need to learn how to apply control theory in your embedded system? >"Applied Control Theory for Embedded Systems" by Tim Wescott >Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html >Maybe I haven't state clearly. My orignal samples are huge,included in x(i,k) ,which is a two dimension vector,and comes from some image. and one dimension of x for every i(ie.x(i,:)) has been proformed fft process.i want to rearray those samples with anothe dimension of x(:,k), so ,k=c*k' has to been performed.Because the indexes of the samples have changed,and c is changed from 0(bigger) to some value bigger than 1;but c is constant for every i. I have no idea of how to decide the 8 points sinc interpolation and the related taylor window.I am appreciated for your further help and suggestions.Thanx a lot.
