Andrew Reilly <andrew-newspost@areilly.bpc-users.org> writes:> On Mon, 23 Jul 2007 18:39:10 -0400, Randy Yates wrote: > >> A DSD quantizer has memory. A linear quantizer does not. DSD != PCM. > > Any quantizer that frequency-shapes the quantization noise has state, just > like any other filter, and such quantizers exist (and are in widespread > use) in multi-bit PCM systems. White quantization noise isn't the > definition of PCM, and I'm surprised that you would suggest that it was.DSD uses a delta-sigma modulator, which is an adaptation of delta modulation, which is distinctly different from linear PCM. As far as I'm concerned, you embarrass yourself with each counter-post and contradiction to these known facts. I don't need your agreement to know up from down and black from white; this is as far as I'm going to go in this thread. -- % Randy Yates % "She's sweet on Wagner-I think she'd die for Beethoven. %% Fuquay-Varina, NC % She love the way Puccini lays down a tune, and %%% 919-577-9882 % Verdi's always creepin' from her room." %%%% <yates@ieee.org> % "Rockaria", *A New World Record*, ELO http://home.earthlink.net/~yatescr
Linear PCM audio: 44.1 KHz, monaural, 1-bit-per-second
Started by ●July 20, 2007
Reply by ●July 23, 20072007-07-23
