Code Composer Hangs while reading data from Host. The CCS stops responding on RTDX_read() function call. I'm using CCS Version 2.0 (target DSP is 5402) I've also read RTDX Troubleshooting Guide in Help and impemented a periodic function that calls RTDX_Poll() but the same problem.... How do I solve this problem... Quick help required... Thanks in advance...!!! ------------> main.c <-------------- #include <std.h> #include <rtdx.h> main() { int i; i = 5; #ifdef RTDX_POLLING_IMPLEMENTATION i *= 5; /* just to ensure that we are in polling implementation */ #endif i++; i++; } RTDX_CreateInputChannel(control_channel); task_1() { int status, i, j; RTDX_enableInput( &control_channel ); status = RTDX_read(&control_channel, &i, 1); /* CCS Hangs here... */ j = i; /* ...never reached */ i++; RTDX_disableInput( &control_channel ); } task_poll() /* Periodic task */ { RTDX_Poll(); } ---------> End of File <------------- -Neo
TI DSP - A newbie problem - reading an integer
Started by ●May 12, 2004
Reply by ●May 12, 20042004-05-12
