Hi, I'm trying to use the "Gaussian Noise Generator" under Simulink 6.3(R14SP3). There are something I dont understand. 1. Is there any mathematic formula to calculate the "Noise Power Density" from the parameters "mean value(I set this to zero)", "variance", and "sample time"? 2. What's the sample rate mean? Should it be the same with the sample rate of signal, or the sample rate of the noise generate decide only the bandwidth of the noise? If latter, why dont use bandwidth instead? Thanks for your answer! ^_^ Cheng
MATLAB Gaussian Noise Generator, variance and power density
Started by ●August 7, 2007
