Question about Cross-Correlation in Frequency-domain
Started by Xuttuh ●August 8, 2007
Greetings,
I am currently writing my diploma-thesis on new spectroscopic methods, and
one of them (2D-Correlation-Spectroscopy) involves cross-correlation of
fourier-transforms. I have encountered a strange issue, for which even my
professor could not supply me with a satisfying answer: When the
cross-correlation of two Fourier-transformed signals is to be calculated,
why do I have to take the complex conjugate of the second signal? This
would mean that the cross-correlation of one fourier-transformed signal
with the complex conjugated fourier-transform of the second signal is
performed, but I always thought this would mean mirroring the imaginary
part of the signal - which would be senseless when the goal is to compare
the two signals.
It would be really great if somebody could enlighten me on that issue.
Thanks in advance,
Xuttuh
On Aug 8, 1:33 pm, "Xuttuh" <peter_rehb...@gmx.de> wrote:
> Greetings, > > I am currently writing my diploma-thesis on new spectroscopic methods, and > one of them (2D-Correlation-Spectroscopy) involves cross-correlation of > fourier-transforms. I have encountered a strange issue, for which even my > professor could not supply me with a satisfying answer: When the > cross-correlation of two Fourier-transformed signals is to be calculated, > why do I have to take the complex conjugate of the second signal? This > would mean that the cross-correlation of one fourier-transformed signal > with the complex conjugated fourier-transform of the second signal is > performed, but I always thought this would mean mirroring the imaginary > part of the signal - which would be senseless when the goal is to compare > the two signals. > > It would be really great if somebody could enlighten me on that issue. > Thanks in advance, > > Xuttuh
The usual definition of cross-correlation contains a complex conjugate on one of the terms: http://en.wikipedia.org/wiki/Cross-correlation And, it makes sense to do this; remember that j^2 = -1, so by inverting the sign of the imaginary part on one of the signals, you get a positive contribution to the correlation value from terms that have the same sign on the imaginary part. Jason
I would normally call what you are doing auto-correlation. Perhaps I am mistaken. If you look into the concept of correlation and matched filtering, you should be able to find a good answer. Phil
>On Aug 8, 1:33 pm, "Xuttuh" <peter_rehb...@gmx.de> wrote: >> Greetings, >> >> I am currently writing my diploma-thesis on new spectroscopic methods,
and
of
my
>> professor could not supply me with a satisfying answer: When the >> cross-correlation of two Fourier-transformed signals is to be
calculated,
>> why do I have to take the complex conjugate of the second signal? This >> would mean that the cross-correlation of one fourier-transformed
signal
>> with the complex conjugated fourier-transform of the second signal is >> performed, but I always thought this would mean mirroring the
imaginary
compare
>> the two signals. >> >> It would be really great if somebody could enlighten me on that issue. >> Thanks in advance, >> >> Xuttuh > >The usual definition of cross-correlation contains a complex conjugate >on one of the terms: > >http://en.wikipedia.org/wiki/Cross-correlation > >And, it makes sense to do this; remember that j^2 = -1, so by >inverting the sign of the imaginary part on one of the signals, you >get a positive contribution to the correlation value from terms that >have the same sign on the imaginary part. > >Jason > >
Thanks for all the quick answers! @ Jason: The hint that the imaginary correlation becomes positive if one of the signals is complex conjugated was a great help! So this all comes from the so-called "Convolution-Theorem" and the corresponding "Correlation-Theorem". Is there any source I can study on the mathematics which lead to those theorems or is there any way one could "illustrate" the process somehow, so that I can understand it more easily? Perhaps there is even a website which illustrates this? Please excuse my questions, I am just an bioengineering-student, and our math-courses did not concentrate very much on signal processing, so I am trying to get around it myself. @ Phil: No, it is not an auto-correlation, it is a correlation of two different signals, which are both Fourier-transformed, just one of them is "complex-conjugate-fourier-transformed", then they are multiplied and the product is integrated.
For a discussion of the practical aspects of the 1D cases look at: http://www.bksv.com/pdf/Bv0013.pdf and http://www.bksv.com/pdf/bv0014.pdf Dale B. Dalrymple http://dbdimages.com
>On Aug 8, 10:33 am, "Xuttuh" <peter_rehb...@gmx.de> wrote: >> Greetings, >> >> I am currently writing my diploma-thesis on new spectroscopic methods,
and
of
my
calculated,
signal
imaginary
compare
>> the two signals. >> >> It would be really great if somebody could enlighten me on that issue. >> Thanks in advance, >> >> Xuttuh > >For a discussion of the practical aspects of the 1D cases look at: >http://www.bksv.com/pdf/Bv0013.pdf >and >http://www.bksv.com/pdf/bv0014.pdf > >Dale B. Dalrymple >http://dbdimages.com > >
Hi,
Intuitively: to rotate back each frequency bin. For example, if the signals match perfectly, the components of the product end up all pointing into the same direction. Then we sum them up, and since they are aligned, the abs. value of the sum is maximized. -Markus
