On Aug 20, 5:55 pm, "mnentwig" <mnent...@elisanet.fi> wrote: Hi Markus,> there are two things that might get mixed up: > - sampling clock offset (in terms of absolute time delay) > - sampling frequency offsetDid not understand the difference. Can you please explain.> The first is trivial in OFDM, it simply appears as frequency dependent > phase shift inside the FFT. But the number of samples before / after the > offset model remain the same.hmmm...need not be. If the packet is long, the presence of sampling clock offset can result in drifts more than the sampling period.> The latter may do real damage to OFDM reception, but is harder to modelAm unable to understand the difference between the first and second. Thanks, Krishna http://dsplog.blogspot.com
Simulation of Sampling Clock Offset
Started by ●August 16, 2007
Reply by ●August 20, 20072007-08-20
Well... imagine we compare time on our wristwatches today. Mine is five minutes late. We do the same again tomorrow: case a) Still five minutes - the difference hasn't changed case b) The watches have drifted further apart - maybe six minutes difference. OFDM is quite sensitive to case b) because the subcarriers lose their orthogonality... the "O" in OFDM :) Cheers Markus
