Hi, I know this a very newbie question; but it seems to me that all RAKE receiver implementation are for CDMA systems. Can it be used for normal modulation schemes e.g. Coherent (BPSK etc) or non coherent (FSK). Thanks.
Rake receiver only for CDMA
Started by ●August 23, 2007
Reply by ●August 23, 20072007-08-23
On Aug 23, 4:53 pm, Affan <int...@gmail.com> wrote:> Hi, > I know this a very newbie question; but it seems to me that all RAKE > receiver implementation are for CDMA systems. Can it be used for > normal modulation schemes e.g. Coherent (BPSK etc) or non coherent > (FSK). > > Thanks.Uh..... no. It's intended for modulations with some "spreading" factor, i.e. the width of the main lobe of the autocorrelation sequence is much smaller than the symbol spacing. BPSK and FSK has no spreading. Julius
On Aug 23, 5:23 pm, julius <juli...@gmail.com> wrote:> On Aug 23, 4:53 pm, Affan <int...@gmail.com> wrote: > > > Hi, > > I know this a very newbie question; but it seems to me that all RAKE > > receiver implementation are for CDMA systems. Can it be used for > > normal modulation schemes e.g. Coherent (BPSK etc) or non coherent > > (FSK). > > > Thanks. > > Uh..... no. > > It's intended for modulations with some "spreading" factor, i.e. the > width of the main lobe of the autocorrelation sequence is much > smaller than the symbol spacing. > > BPSK and FSK has no spreading. > > JuliusI may have spoken too quickly: I assumed you were talking about a multipath channel. If there is no multipath, then a matched filter basically works as a 1-tap rake receiver. So it depends on what you mean by "rake receiver". Julius
Reply by ●August 24, 20072007-08-24
>> I may have spoken too quicklyMaybe not... I would have answered the same, only in different words: - A rake receiver works, because it can "block" a time-delayed part of the signal by despreading. Different rake fingers can be assigned to different time delays (multipath), and the outputs are then combined. -For non-spread signals - for example standard QPSK/QAM/etc streams - a time-delayed signal appears simply as a different symbol stream. A branch of a rake receiver has no means to isolate a single delay path of the channel profile. Cheers Markus
