Tim Wescott <tim@seemywebsite.com> writes:> [...] > And nonlinear effects, to, I would imagine. > > Altogether it would be an interesting challenge, particularly if you > wanted to mimic _different_ gramophones and recording equipment.By the way, here are a couple of recordings kindly made available by Serge Auckland. http://audiopages.googlepages.com/otherstuff You'll have to scroll down a bit to get to two mp3 links of his gramophone recordings. -- % Randy Yates % "Maybe one day I'll feel her cold embrace, %% Fuquay-Varina, NC % and kiss her interface, %%% 919-577-9882 % til then, I'll leave her alone." %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://home.earthlink.net/~yatescr
Filter to Immitate Gramophone
Started by ●August 27, 2007
Reply by ●August 28, 20072007-08-28
Do not forget adding some scratches, the click(s) for each turn of the record. And sometime you need to push the arm it you got stuck in same groove. (I know there is only one groove on each side ;-) -- Christen Fihl http://HSPascal.Fihl.net/
Reply by ●August 29, 20072007-08-29
In article <1188239338.408481.89130@50g2000hsm.googlegroups.com>, ghuang@comcast.net says...> > >I wonder if there exist some spec or transfer function of a filter >that would immitate the responce of an old gramophone or 78s. I am >retrfitting an old gramophone with modern mp3 electronics but like it >to sound more "authentic". >I would start here: http://www.victor-victrola.com/Victrola%20Horns.htm As other posters have noted, you may want to add noise, nonlinear distortion, and clicks if you really want the simulation to be believable.
Reply by ●August 30, 20072007-08-30
On 2007-08-28, Randy Yates <yates@ieee.org> wrote:> Tim Wescott <tim@seemywebsite.com> writes: >> [...] >> And nonlinear effects, to, I would imagine. >> >> Altogether it would be an interesting challenge, particularly if you >> wanted to mimic _different_ gramophones and recording equipment. > > By the way, here are a couple of recordings kindly made available > by Serge Auckland. > > http://audiopages.googlepages.com/otherstuff > > You'll have to scroll down a bit to get to two mp3 links of > his gramophone recordings.I have no great insight into solving your problem, but it's obvious that all sorts of things are going on here which give the gramophne its characteristic sound. 1. It's certainly got weak response to low frequencies. 2. There is a fair amount of hiss, which you could probably characterize with a bit of work. 3. There is a fair amount of popping. 4. I'm curious if the noise is correlated to the rotational speed of the gramophone... 5. It's pretty clear that certain frequencies result in a resonant buzz. Neat! Mark
Reply by ●September 3, 20072007-09-03
Thanks for all the suggestions and comments. I guess I will start with the "linear" part - frequency or impulse response, then noise and pops. For non-linearity, I might start with a threshold - above the threshold, the output follows a polynomial curve. There is also a partition issue for linear filtering. Some filtering (ie. band- limiting) will be before the NL operation and some (ie. resonance), after. The good thing is that the project does not require any special DSP hardware. I can simply convert CD data to linear PCM wav files, do whatever I need on a PC, then convert the processed samples to mp3 for playing.
