Hi, I'm doing simulation in frame synchronization of OFDM by using Cocentric System Studio. My task is to generate preamble and do sync in both time and frequency domain. Channel model is not necessary. Does anyone have any idea or any sources related to my task ? I'm a newbie in communication. So it would be best if you give me some fundamental sources about synch in OFDM and some simulation models? Thanks a lot.
Frame Synchronization
Started by ●August 29, 2007
Reply by ●August 30, 20072007-08-30
Without a channel model, whatever you do may not be very meaningful. Especially in synchronization. But here are some references for starting. M=2E Speth, S. Fechtel, G. Fock, H. Meyr,"Optimum Receiver Design for OFDM-Based Broadband Transmission-Part-2: A Case Study": IEEE Trans. Commun., vol.49,pp. 571-578, April 2001. Yun Chiu, Dejan Markovic, Haiyun Tang, Ning Zhang, "OFDM Receiver Design" Daniel Landst=F6rm et al., "Symbol Time Offset Estimation in Coherent OFDM Systems", IEEE Trans. Commun., vol. 50, pp. 545-549, April 2002. Jan-Jaap van de Beek, M. Sandell, Per Ola B=F6rjesson, "ML Estimation of Time and Frequency Offset in OFDM Systems", IEEE Trans. Signal Processing., vol. 45, pp. 1800-1805, July 1997. You would of course need some have communication basics. Hope it helps. Regards Piyush On Aug 29, 5:03 pm, "cau2danang" <sstrong...@yahoo.com> wrote:> Hi, > > I'm doing simulation in frame synchronization of OFDM by using Cocentric > System Studio. My task is to generate preamble and do sync in both time a=nd> frequency domain. Channel model is not necessary. > > Does anyone have any idea or any sources related to my task ? I'm a > newbie in communication. So it would be best if you give me some > fundamental sources about synch in OFDM and some simulation models? Thanks > a lot.
Hi Piyush, Thanks for your reply. Actually I have to implement a channel model in later stage. Do you have any source about modelling amateur radio (RFI)? I know that amateur radio interference is a narrow band tupe but I don't know how to model it?>Without a channel model, whatever you do may not be very meaningful. >Especially in synchronization. But here are some references for >starting. > >M=2E Speth, S. Fechtel, G. Fock, H. Meyr,"Optimum Receiver Design for >OFDM-Based Broadband Transmission-Part-2: A Case Study": IEEE Trans. >Commun., vol.49,pp. 571-578, April 2001. >Yun Chiu, Dejan Markovic, Haiyun Tang, Ning Zhang, "OFDM Receiver >Design" >Daniel Landst=F6rm et al., "Symbol Time Offset Estimation in Coherent >OFDM Systems", IEEE Trans. Commun., vol. 50, pp. 545-549, April 2002. >Jan-Jaap van de Beek, M. Sandell, Per Ola B=F6rjesson, "ML Estimation of >Time and Frequency Offset in OFDM Systems", IEEE Trans. Signal >Processing., vol. 45, pp. 1800-1805, July 1997. > >You would of course need some have communication basics. > >Hope it helps. > >Regards >Piyush > >On Aug 29, 5:03 pm, "cau2danang" <sstrong...@yahoo.com> wrote: >> Hi, >> >> I'm doing simulation in frame synchronization of OFDM by usingCocentric>> System Studio. My task is to generate preamble and do sync in both timea=>nd >> frequency domain. Channel model is not necessary. >> >> Does anyone have any idea or any sources related to my task ? I'm a >> newbie in communication. So it would be best if you give me some >> fundamental sources about synch in OFDM and some simulation models?Thanks>> a lot. > > >
