Hi there, I have the following question: 1) For each modulation scheme, there is a corresponding bandwidth efficiency (let's call it n). n = R/B where R is the data rate and B is the bandwidth. My question is can I simple say R = n*B no matter how big B is. i.e. can I reach higher data rate by increasing the bandwidth using the same modulation scheme. 2) If the above equation can not be applied due to each modulation scheme data rate limit, how can I calculate the data rate given the modulation scheme, coding and bandwidth? (Assume the certain SINR is good enough) thanks!! Yiu
Data Rate, bandwidth
Started by ●September 10, 2007
Reply by ●September 10, 20072007-09-10
In principle yes. All of the following - bit rate - symbol rate - bandwidth - absolute transmitted power - absolute noise power in the BW assuming AWGN can scale linearly with the same factor. A dumb example: Use two / three / x cellphones at the same time. As long as they can use different radio channels (=more bandwidth), the total capacity scales linearly. Needless to say, this is a very simple answer to a question that can get quite complex, depending on where you're heading. Cheers Markus
Thanks Markus. In general, can I use the bandwidth efficiency for particular modulation to calculate the data rate given bandwidth? E.g. 8-PSK, the bandwidth efficiency is 1.5, if bandwidth is 640MHz, will I get 1.5x640Mbps = 960Mbps? thanks again. really appreciate your help. Yiu>In principle yes. >All of the following >- bit rate >- symbol rate >- bandwidth >- absolute transmitted power >- absolute noise power in the BW assuming AWGN >can scale linearly with the same factor. > >A dumb example: Use two / three / x cellphones at the same time. As long >as they can use different radio channels (=more bandwidth), the total >capacity scales linearly. > >Needless to say, this is a very simple answer to a question that can get >quite complex, depending on where you're heading. > >Cheers > >Markus >
On Mon, 10 Sep 2007 10:24:45 -0500, "blueyiu" <candy@cs.pdx.edu> wrote:>Thanks Markus. > >In general, can I use the bandwidth efficiency for particular modulation >to calculate the data rate given bandwidth? E.g. 8-PSK, the bandwidth >efficiency is 1.5, if bandwidth is 640MHz, will I get 1.5x640Mbps = >960Mbps? > >thanks again. really appreciate your help. >YiuIt sounds like you're including an assumed code rate of R = 1/2, since uncoded 8PSK is really 3 bits per symbol, not 1.5. For the most part, though, you're correct that data rate scales linearly with bandwidth for a given modulation order and code rate. Practical effects like spectrum availability and transmit power tend to limit things, though. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org
Reply by ●July 26, 20102010-07-26
>On Mon, 10 Sep 2007 10:24:45 -0500, "blueyiu" <candy@cs.pdx.edu> >wrote: > >>Thanks Markus. >> >>In general, can I use the bandwidth efficiency for particular modulation >>to calculate the data rate given bandwidth? E.g. 8-PSK, the bandwidth >>efficiency is 1.5, if bandwidth is 640MHz, will I get 1.5x640Mbps = >>960Mbps? >> >>thanks again. really appreciate your help. >>Yiu > >It sounds like you're including an assumed code rate of R = 1/2, since >uncoded 8PSK is really 3 bits per symbol, not 1.5. > >For the most part, though, you're correct that data rate scales >linearly with bandwidth for a given modulation order and code rate. > >Practical effects like spectrum availability and transmit power tend >to limit things, though. > >Eric Jacobsen >Minister of Algorithms >Abineau Communications >http://www.ericjacobsen.org >Might Yiu are implying a Trellis Coded Modulation?
