Richard Fry wrote:>>Other than brief portions of the evening news the question arises: >>What's the whole point in restoration these days? If OTA-TV really goes >>digital some distant day we might not even bother buying a new set. > > _________ > > Accurate colour reproduction requires accurate transmission of the > luminance (brightness) value of each colour, which is set by a > specific, DC-coupled voltage. If the video signal was transmitted > using AC coupling, then luminance values would be a function of the > average voltage of the video waveform. > > For that matter accurate monochome reproduction also requires DC > coupling, but it is not as objectionable if not used (cheap TV set, > etc). > > Also - the purpose of inverting video for transmission is to transmit > the peaks of sync pulses at +100% modulation, which allows TV > receivers to show the most stable picture in the presence of noise > (eg, fringes of the coverage area of the TV station). > > RF > RCA Broadcast Field Engineer, retired >I know how it works, Richard. My point was, why restore the clamp level or any other level if the contents of the transmission itself ain't worth watching? It they did more re-runs of Andy Griffith or Bonanza or whatever, ok, but not with the average programming these days. -- Regards, Joerg http://www.analogconsultants.com
Why is video inverted for transmission?
Started by ●September 19, 2007
Reply by ●September 20, 20072007-09-20
> Well, the luminance ("Y") is defined by the instantaneous > DC voltage of the signal, but none of the color information > is carried there. The color information comes through on > a 3.579545MHz subcarrier ...______ Luminance, hue and saturation information are required to define every color, so it isn't strictly accurate to write that "color information comes through on a 3.58.. MHz subcarrier." Chrominance information does, but luminance information is contained in the standard monochrome video spectrum from about 60 Hz to about 4.2 MHz (NTSC). It takes both the luminance and the chrominance signals to convey accurate color. For example, if the luminance information is removed from a standard color bar test signal, the color bars will not look the same as before.
"Don Pearce" <nospam@nospam.com> wrote in message news:46f790a7.202443468@news.plus.net...> Huh? This is just nonsense. The noise doesn't live at the bottom of > the signal where the white is. The noise accompanies the signal > whatever level it is at. The black will have just as much noise in it > as the white. The reason why small signals appear noisier is that you > have to apply gain to make them bigger - making the noise bigger too.Not in the case of video, though - the reason that the blacks are "more sensitive to noise" than the white is actually because our eyes are more sensitive to small changes in dark regions than in light regions. As you noted, though, the noise is going to hit the blacks just as much as the whites within the signal - but as others noted, it's better that a brief high-amplitude noise spike make a "black dot" in a white region than the other way around. The only part of the standard I'm aware of that was specifically put in to handle the increased sensitivty to black-region noise was a modification to the assumed standard response ("gamma") curve. And, of course, the other (and possibly the primary) reason for the inverted transmission was to put the most "oomph" behind the sync pulses - which means that even those in the fringe areas can get a stable, albeit snowy, picture. Bob M.
On 9/20/2007, Allen posted this:> Arny Krueger wrote: > <snip> >> Once I got *tired* of that, they moved me to Germany, where the radars were >> still in the open air (sun, sleet, rain, waist-deep snow and subzero >> temps), on individualized hilltops. The scenery in Germany included a 270 >> degree vista of a large valley, complete with farms, little towns, and a >> castle or two. >> >> > You got to see more of the world than I did. My time was spent keeping the > North Korean air force from destroying Pittsburgh. > AllenOT (I guess) My first thought at the start of this thread was "OMG, another radium thread", but I read a few posts anyway. So: 1. I'm learning something about why black is full signal - actually a meaningful question after all. 2. I'm enjoying the tales in this part of the thread about pizza ovens and so forth. I even had a couple of LOLs... -- Gene E. Bloch (Gino) letters617blochg3251 (replace the numbers by "at" and "dotcom")
"Richard Fry" wrote ...>> Well, the luminance ("Y") is defined by the instantaneous >> DC voltage of the signal, but none of the color information >> is carried there. The color information comes through on >> a 3.579545MHz subcarrier ... > ______ > > Luminance, hue and saturation information are required to define every > color, so it isn't strictly accurate to write that "color information > comes through on a 3.58.. MHz subcarrier." Chrominance information > does, but luminance information is contained in the standard > monochrome video spectrum from about 60 Hz to about 4.2 MHz (NTSC). It > takes both the luminance and the chrominance signals to convey > accurate color. > > For example, if the luminance information is removed from a standard > color bar test signal, the color bars will not look the same as before.Yes, you are correct, one cannot decode a full NTSC composite color signal without the "Y" luminance part. OTOH, the backwards- compatibility feature of NTSC guarantees that the "Y" luminance part will stand on its own without the "C" chrominance portion.
Richard Fry wrote:> Luminance, hue and saturation information are required to define every > color, so it isn't strictly accurate to write that "color information > comes through on a 3.58.. MHz subcarrier." Chrominance information > does, but luminance information is contained in the standard > monochrome video spectrum from about 60 Hz to about 4.2 MHz (NTSC). It > takes both the luminance and the chrominance signals to convey > accurate color.> For example, if the luminance information is removed from a standard > color bar test signal, the color bars will not look the same as before.If luminance is removed from a monochrome picture it won't look the same as before, either. If chrominance is removed from a color picture it should form a good monochrome picture. Since gamma correction is done differently for color, the resulting luminance isn't exactly correct. Given that, I would have to agree that some chrominance information is in the luminance signal, but it is relatively small. -- glen
Richard Crowley wrote: (snip)> When it comes right down to it, ALL analog video is AC > coupled. Through many stages of electronics, to be sure, > but even if all the electronics were DC coupled, the trip > through the air (or written to and read back from a tape) > is AC coupled.On tape, luminance is usually an FM signal, which could be considered to preserve DC. (If you are careful with the calibration.) Otherwise, yes. -- glen
