FFT and estimating frequencies not on discrete points
Started by Unknown ●September 23, 2007
On Sep 25, 2:57 pm, "mnentwig" <mnent...@elisanet.fi> wrote:
> >>Bad in what way? Maximum likelihood is hard to beat. > > Huh? What does FFT have to do with maximum likelyhood? > > From a practical point of view, I doubt think that a majority of carrier > recovery schemes relies on FFT, and that may be what the OP really needs. > > >Why FM demod? Once the PLL is locked up, read it's frequency. If the > >frequency is variable, the PLL *is* the FM demod. > > That's right and that's my point. But search for PLL alone, and I doubt > something relevant will come up at the top. Search for FM demodulation > -and- PLL... well, you said it already. > > -mn
The original post says nothing about carrier recovery. As far as Maxlikelihood, read the article I cited.
Ah, we are talking about different things.
Those discussions are usually the best. Well, the most entertaining for
the audience at least, not necessarily the most productive.
I am actually not arguing with you.
My statement was and is that the original poster might need a standard
"Proakis-chapter-six" carrier recovery instead of a wild FFT scheme, as is
the subject of the thread. Yes, the original post says nothing about
carrier recovery. But that's still what might be the most useful.
I hope that clarifies.
-mn
All of you,
Thank you very much for the information. Sorry for the delay on this,
I didn't have time to do this in the past month, so I decided I will
wait until I can do it well. I tried some of the things mentioned
above (like quadratic interpolation found in the links mnentwig gave)
and I applied Hann window (which I didn't before), so it worked pretty
well. I am still not completely satisfied with the result and I will
look into this a little more.
Thanks again and good day to you all!
On Sep 23, 12:26 pm, wi...@yahoo.com wrote:
> Assume there is a real function f and its spectrum F. If f is discrete > sampled, we have samples at some t = st * k, where st is sampling > period and k = 0, 1, 2, ..., N - 1. Also assume every frequency in f > is within [-fc..fc] range, fc = Nyqist frequency. If f is a simple > sine function whose minimums, zeros and maximums are at the sampling > points, F will be very "good", without leakage and just by looking at > some point of F we can see what is the frequency m of f = > sin(2*pi*m). > > However, if this is not the case, i.e. extremal points of f do not lay > on the sampled points (k = 0, 1, 2, ..., N - 1), this will not be the > case - there will be leakage. Assume that I calculated F from the > known f and I have N/2 bins of F at my hand. Bin n - 1 is for > frequency m - j, bin n is for frequency m and bin n + 1 for frequency > m + j. How can I calculate the power for frequency e.g. m - j / 2 or m > + j / 3 or such? That is, calculate the power at some frequency for > which I don't have F defined, which I presume would allow me to see > which frequency is the "main" one (let away special cases).
dunno if you're interested, but i did a paper in 2001 (Mohonk, geez, i wonder if it's going on now?) where, in the case of using a Gaussian window on the data, i had an reasonably elegant solution for estimating the instantaneous frequency (at the midddle of the window), the sweep-rate, and ramp-rate in log amplitude (and amplitude). it requires FFT, discrete-derivative, complex log, least-squares fit to a linear function, and a closed form expression for extracting the parameters we want out of the complex slope and offset parameters from the linear function. it *does* assume it's not interfered with significantly by ohter swept sinusoids. that's a deficiency in the algorithm. r b-j
