Hello, I am trying to capture the motion of a mechanism with a high speed camera. The motion is a transient impact that reverses direction with about 100 g's of acceleration. I have the displacement curve as acquired from a laser doppler sensor and I'm reading it on an oscilloscope with very high sampling rate. However, the camera is a much slower rate (4000 fps). My question: How do you determine an adequate sampling rate for a transient event such as this? The Tektronix notes say you need a BW of 5 times the highest frequency content of your signal. They also try to relate bandwidth to rise time, but I don't know how that applies here. I will transform my displacement signal into the frequency domain to look at the frequency content next. Kurt
Adequate sampling rate for a transient mechanical event?
Started by ●May 5, 2004
Reply by ●May 5, 20042004-05-05
Kurt Sutherland wrote:> Hello, > > I am trying to capture the motion of a mechanism with a high speed > camera. The motion is a transient impact that reverses direction > with about 100 g's of acceleration. > > I have the displacement curve as acquired from a laser doppler sensor > and I'm > reading it on an oscilloscope with very high sampling rate. However, > the camera is a much slower rate (4000 fps). My question: > > How do you determine an adequate sampling rate for a transient event > such > as this? The Tektronix notes say you need a BW of 5 times the highest > frequency content of your signal. They also try to relate bandwidth to > rise time, but I don't know how that applies here. > > I will transform my displacement signal into the frequency domain to > look at the frequency content next. > > KurtYou want to sample fast enough so that the largest picture-to-picture difference you see is smaller than the smallest error that you can stand. Transforming the displacement into the frequency domain will give you part of the answer, but it won't help if you can't relate it to your required error. As a first-order cut I'd select an error energy that I can call acceptable, then find the frequency that has no more than that much energy above it (badly stated, sorry). You need to sample at twice that magic frequency. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Kurt Sutherland wrote:> I am trying to capture the motion of a mechanism with a high speed > camera. The motion is a transient impact that reverses direction > with about 100 g's of acceleration.> I have the displacement curve as acquired from a laser doppler sensor > and I'm > reading it on an oscilloscope with very high sampling rate. However, > the camera is a much slower rate (4000 fps). My question:> How do you determine an adequate sampling rate for a transient event > such as this?First, if it is an oscillating system the usual twice the frequency rule applies. You definitely don't want to be below that. > The Tektronix notes say you need a BW of 5 times the highest> frequency content of your signal. They also try to relate bandwidth to > rise time, but I don't know how that applies here.The rise time relates to the highest frequency component in the Fourier transform, which you should sample more than twice the frequency of. My first approximation to that, given that you state the acceleration, is the square root of the ratio of the acceleration to total displacement, and sample at twice that frequency.> I will transform my displacement signal into the frequency domain to > look at the frequency content next.That is a good way, too. -- glen
Reply by ●May 6, 20042004-05-06
Kurt Sutherland wrote:> Hello, > > I am trying to capture the motion of a mechanism with a high speed > camera. The motion is a transient impact that reverses direction > with about 100 g's of acceleration. > > I have the displacement curve as acquired from a laser doppler > sensor and I'm > reading it on an oscilloscope with very high sampling rate. > However, > the camera is a much slower rate (4000 fps). My question: > > How do you determine an adequate sampling rate for a transient > event such as this?Your event is non-repetitive, therefore the usual 2xmaxFrequency rule doesn't hold.> The Tektronix notes say you need a BW of 5 times the > highest frequency content of your signal.This seems a fair compromise. However, since you know the origin of your frequency content, you are probably able to estimate the highest frequency components in your signal. If I take an airbag as an example (where such high accelerations appear), and I want to sense the pressure of the airbag against an obstacle like a person's face, then I know that in spite of the high acceleration the pressure curve will increase softly, not abruptly, which means, that I need not bother about very high frequencies. Your camera and/or your scope reading should give you snapshots of the curve, the interpolation should be possible out of the knowledge about the signal source. Thus, I'd try to calculate the really interesting frequency content from the curve on the oscilloscope. Derive the scope curve and smoothen it as much as you'd allow according to what you know about the signal. I'd guess that you end up with an acceptable time distance of let's say 0.1ms, so that a sampling rate of 10kS/s might be enough. Probably, your camera will be fast enough. To prove that, gather a couple of sequences one after the other, compare the pictures and watch out for such where the displacement changes rapidly between consequent pictures. If nothing astonishing happens so that you think, I need some more pictures in between here, then your sampling rate is probably fast enough. Nevertheless, it depends on what you're really watching...> They also try to relate > bandwidth to rise time, but I don't know how that applies here.Take a low pass filter, apply a step signal to it, and watch the response. What you see is the rise time which the filter allows. Vice versa: if you want to see a response quick enough to monitor an event with a sharp rise/fall, you need a filter with high enough passband edge. The exact relation depends on the sort of filter which you have in your system.> > I will transform my displacement signal into the frequency domain > to look at the frequency content next.The result will depend on the decision about sampling rate. You'll not see higher frequencies in the frequency domain even if they're present in the signal - they will only spoil your result.> > KurtBernhard
Kurt Sutherland wrote:> Hello, > > I am trying to capture the motion of a mechanism with a high speed > camera. The motion is a transient impact that reverses direction > with about 100 g's of acceleration. > > I have the displacement curve as acquired from a laser doppler sensor > and I'm > reading it on an oscilloscope with very high sampling rate. However, > the camera is a much slower rate (4000 fps). My question: > > How do you determine an adequate sampling rate for a transient event > such > as this? The Tektronix notes say you need a BW of 5 times the highest > frequency content of your signal. They also try to relate bandwidth to > rise time, but I don't know how that applies here. > > I will transform my displacement signal into the frequency domain to > look at the frequency content next. > > KurtThe 5X Nyquist is about right. There is a AL Nuttal paper somewhere that goes into a rigorous analysis on why you need about 4.5X instead of 2X for the transient case. I've never actually seen the paper so I can't outline his reasoning. The fact that Tektronix gives a similar ball park number would tend to make me accept it. Fundamentally a transient has infinite bandwidth so the strictly band limited requirement in Nyquist sampling doesn't hold. Actually the strictly band limited requirement of Nyquist sampling is never perfectly meet in practice. I recall discovering the first time that I used a Nicolet digital O-scope that oversampling was needed to get a nice looking trace. Nicolet used a polynomial interpolation scheme to display the actual waveform.
"Kurt Sutherland" <kurtsutherland@comcast.net> wrote in message news:30d41dc9.0405051333.1dccfe19@posting.google.com...> Hello, > > I am trying to capture the motion of a mechanism with a high speed > camera. The motion is a transient impact that reverses direction > with about 100 g's of acceleration. > > I have the displacement curve as acquired from a laser doppler sensor > and I'm > reading it on an oscilloscope with very high sampling rate. However, > the camera is a much slower rate (4000 fps). My question: > > How do you determine an adequate sampling rate for a transient event > such > as this? The Tektronix notes say you need a BW of 5 times the highest > frequency content of your signal. They also try to relate bandwidth to > rise time, but I don't know how that applies here. > > I will transform my displacement signal into the frequency domain to > look at the frequency content next.Kurt, It looks like you have the right idea. The displacement measurement, with its high sample rate, should give you adequate information. Another way to look at it was already suggested - how much displacement error can you stand between frames? Maybe instead of thinking about sampling in time we should be thinking about sampling in space. Then you need to sample at a rate that is greater than 2x the spatial frequency or at a spatial interval that is less than 1/2 the spatial separation of important features. Or, in your case, that is less than the allowable position error of the measurement. If you know the displacement as a function of time (sampled at a very high rate) then perhaps you can relate the two: Let's pose the question this way: A high-speed object at velocity v0, at time t0, starts to decelerate at time t0. It reverses direction and just reaches velocity -v0 = v1 at time t1. What is the (maximum) displacement when the velocity reaches zero between t0 and t1? How accurately must that displacement be measured? There are two approaches that I'm sure someone will bring up: 1) You can sample the position with a camera and interpolate the position from those frames. If you know a lot about the acceleration, you might do a very good job with this approach. I'll not discuss this right now. 2) If you must brute force the measurement by only taking sample frames and assume there is no interpolation, then consider this: If you only sample at t0 and t1, then you haven't got a very good measurement of the maximum displacement. If you sample at intervals of (t1-t0)/2 then it could be much better but only if you can register the samples at exactly t1 and t0 and only if the acceleration is constant. Assuming you can't do this we might assume that you are perfectly misaligned with t1 and t0 - so it would be better to sample at intervals of (t1-t0)/4 and capture displacements at t0, t1 and [t0 + (t1-t0)/2] as well as at [t0 + (t1-t0)/4] and at [t0 + 3*(t1-t0)/4] But you can't know that you are perfectly misaligned either. So even the approach above could yield position uncertainties as great as perhaps the equivalent displacement to a time interval of (t1-t0)/8 (using linear interpolation) ..... and so on. You didn't say how you're going to use the frames. Given that you have the high rate oscilloscope displacement data and know what you're going to do with the frames, I'd say you already have enough information to decide what to do with the camera. It does appear that synching the camera with the "event" could help by as much as a factor of 2 over the worst case arbitrary camera timing. Also, if the experiment is repeatable, how about taking multiple frame sequences with a variety of synch points relative to the "event" and interleaving whole frame sets with appropriate temporal registration? The result would likely be somehwat "noisy" but could have some benefit. The latter could be viewed as follows: What if the experiment were noiseless / repeatable and was actually continuous and periodic. It just keeps happening over and over again with the same frequency. Then you could sample the periodic result at an interval that is slightly shorter than the period - and not harmonically related ... like 3/pi of the period. The longer samples are taken, the more "filled" in the period with samples. Now, this argues that the sample interval never has to be more than slightly shorter than 2*(1/2) the period, no matter the frequency content of the signal - as long as one can spend enough time sampling. That seems to fly in the face of common thinking. I guess the "trick" is very accurately knowing what the period is so that succeeding samples can be registered with samples from preceding periods. Normally we don't allow ourselves to "know" that in general DSP processing as compared to computing a Fourier Series. Fred
