Narax wrote:> Sorry, I accidentally hit the "Send Message!" button. > >> Notice that the pre-emphasis has about 15 dB or more boost at high >> frequencies, make sure that this does not casue OVEVERMODULATION to >> your modulator. >> >> Mark > > Thank you for this hint - I didn't take this in concideration till now and > I think this is the first thing the check out. > > > One more question about the RC-curcuit: You said that I should take its > phase response. But a simple RC-curcuit has a diffrent magnitude response > than I want to achieve. Is a mix of the desired magnitude response and the > RC-circuit's phase response a good design?The deemphasis filter in the receiver is a simple RC. The preemphasis filter should complement it, and the complement is also a simple RC. Why do you want a different response? Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
designing a preemphasis filter
Started by ●October 4, 2007
Reply by ●October 10, 20072007-10-10
Reply by ●October 12, 20072007-10-12
>The deemphasis filter in the receiver is a simple RC. The preemphasis >filter should complement it, and the complement is also a simple RC. Why>do you want a different response? > >JerryMy mistake. I don't want another response. Things are beginning to work fine - I just now took a look at the results from the FDLS algorithm and they are good. As always I have another question: What is the artificial delay good for? I know that things don't work fine without it, but why?
Narax wrote: ...> Things are beginning to work fine - I just now took a look at the results > from the FDLS algorithm and they are good. As always I have another > question: What is the artificial delay good for? I know that things don't > work fine without it, but why?How does the frequency-domain Least squares algorithm enter the picture? I don't know which delay you mean, but one commonly adds a delay to match an unavoidable delay in a parallel part of a process. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
