Hi i'm new to using Fpga.My project is design of modulator using Fpga based on Dsp technology.My data rate is 12Mb and Intermeadiate freq is 140 Mhz. I decided to use D8psk modulation technique. i want to choose Fpga for this design.which parameters have to be considered for choosing fpga.
selection of Fpga
Started by ●October 8, 2007
Reply by ●October 8, 20072007-10-08
kumari wrote:> Hi > i'm new to using Fpga.My project is design of modulator using Fpga based > on Dsp technology.My data rate is 12Mb and Intermeadiate freq is 140 > Mhz. > I decided to use D8psk modulation technique. i want to choose Fpga for > this design.which parameters have to be considered for choosing fpga. > >You may want to cross-post this question to the fpga newsgroup (I trust you haven't multiple-posted). Scratch out your modulator design as a block diagram, then look at the arithmetical operations you're going to be doing and the sampling rate you feel you need to achieve. I suspect there will be a substantial number of multiplies, with some phase-to-sine conversions. This would imply you want an FPGA that has multiplier blocks and memory blocks -- fortunately these are easy to come by. Then go looking for an FPGA that's easy to work with. I can't help you here -- my little bit of experience with FPGAs is with Xilinx parts and it's a few years old now. Moreover my choice had more to do with having a local circle of friends that includes more people with practical Xilinx experience than with other parts, and because the local Xilinx app engineer is a friendly and helpful guy. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
