When I installed matlab ( on SuSe 10.2 64 bit ) and I try to start the shell tells me go to /home dir and to read the fail "java.log. 6338"....And its contend is : Error occurred during initialization of VM Could not reserve enough space for code cache Stack Trace: [0] libjvm.so:0x00002aaaab771989(0x7fffebb30820, 0x2aaaab4f28ef, 0x00660960 ", 0x00660960 ") [1] libjvm.so:0x00002aaaab5c0955(0x00660960 ", 0x00660960 ", 0x7fffebb309b4, 0x00660960 ") [2] libjvm.so:0x00002aaaab4f28ef(0x7fffebb30840, 0x2aaaab58fa4d, 0x7fffebb309a0, 0x2aaaab8206c9) [3] libjvm.so:0x00002aaaab4f2909(0x7fffebb309a0, 0x2aaaab8206c9, 1, 0x7fffebb308f0) [4] libjvm.so:0x00002aaaab58fa4d(1, 0x7fffebb308f0, 0x7fffebb30960, 4) [5] libjvm.so:0x00002aaaab8206c9(0x1bfb42b40, 144, 8, 0x2b4fbfb42b40 "/opt/matlab/sys/java/jre/glnxa64..") [6] libjvm.so:JNI_CreateJavaVM~(0x2aaaaaae7195 "/usr/share/icons", 0x2aaaaaae6e83 "default", 1, 0x00631010) + 103 bytes ------------------------------------------------------------------------ Fatal Java Exception detected at Fri Oct 12 20:12:03 2007 ------------------------------------------------------------------------ Configuration: MATLAB Version: 7.4.0.287 (R2007a) MATLAB License: 161051 Operating System: Linux 2.6.18.2-34-default #1 SMP Mon Nov 27 11:46:27 UTC 2006 x86_64 GNU C Library: 2.5 stable Window System: The X.Org Foundation (70199902), display :0.0 Current Visual: 0x21 (class 4, depth 24) Virtual Machine: Java is not enabled Default Charset: UTF-8 Java is not enabled But the then I start MatLab in bash with no java ( :~>matlab_dir/ matlab -nojvm ) it works !!!! And I understand that there is a problem with jvm but a had java_6u2 installed and worked well......and a cant managed with this problem....may be a had to use "javaX" commands to increase the memory used by jvm or something else..>>>>>>>>>>PLEASE I REALLY NEED MATLAB >>>>>> If someone can halp me let do it :-) Thank to all read this !!!
Problem with jvm on Matlab
Started by ●October 12, 2007
