Sorry for bothering you with the question that you probably heard a hundred times... I'm new to DSPs and would like to buy a DSP starter kit to learn. I'd like to have some practical results from this work, so I aim to develop an audio processing unit taking stereo audio signal from CD, upsampling it, applying some filters and putting it out through high sample rate DACs (192 kHz, 5 channels would be better but I guess 4 will work for start). Please help me identify not very expensive kit that would better serve my project. Thanks!
Help choosing a DSP starter kit.
Started by ●November 4, 2007
Reply by ●November 4, 20072007-11-04
"Decay" <dan_nomad@mail.ru> writes:> Sorry for bothering you with the question that you probably heard a hundred > times... > > I'm new to DSPs and would like to buy a DSP starter kit to learn. I'd like > to have some practical results from this work, so I aim to develop an audio > processing unit taking stereo audio signal from CD, upsampling it, applying > some filters and putting it out through high sample rate DACs (192 kHz, 5 > channels would be better but I guess 4 will work for start). > Please help me identify not very expensive kit that would better serve my > project.I suggest that you first identify the application area that you'd like to work in. Broadly, those could be: audio, communications, or video. I would then look for starter kits from the following based on area: audio: Freescale, TI 55x communications TI 55x, 64x video: TI 64x, DaVinci. -- % Randy Yates % "The dreamer, the unwoken fool - %% Fuquay-Varina, NC % in dreams, no pain will kiss the brow..." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Eldorado Overture', *Eldorado*, ELO http://www.digitalsignallabs.com
> >I suggest that you first identify the application area that you'd like >to work in. Broadly, those could be: audio, communications, or video. >I would then look for starter kits from the following based on area: > > audio: Freescale, TI 55x > communications TI 55x, 64x > video: TI 64x, DaVinci. > >-- >% Randy Yates % "The dreamer, the unwoken fool - >%% Fuquay-Varina, NC % in dreams, no pain will kiss thebrow...">%%% 919-577-9882 % >%%%% <yates@ieee.org> % 'Eldorado Overture', *Eldorado*, ELO >http://www.digitalsignallabs.com >Hi, thank you for your reply. As I outlined earlier I'd like to work in audio area. Also some specifics: ADC is not required on the board, 4 or 5 ch DAC (96 or 192 kHz). Not sure about the speed, I guess most DSPs can handle simple filtering of 5 ch in real time. So you advise for 55xx series board. As I see this is low power fixed point dsp. What is better for high quality real time audio processing fixed or floating point? Also this is low power chip, I don't think it's critical in my case, are there any trade-offs related to low power consumtion? The only 55xx kit I was able to find on TI's site is 5509 one, and it doesn't seem to have 5 output channels (DACs)... However 24 bit is good. Is there any specific kit you have in mind for my application?
"Decay" <dan_nomad@mail.ru> writes:>> >>I suggest that you first identify the application area that you'd like >>to work in. Broadly, those could be: audio, communications, or video. >>I would then look for starter kits from the following based on area: >> >> audio: Freescale, TI 55x >> communications TI 55x, 64x >> video: TI 64x, DaVinci. >> >>-- >>% Randy Yates % "The dreamer, the unwoken fool - >>%% Fuquay-Varina, NC % in dreams, no pain will kiss the > brow..." >>%%% 919-577-9882 % >>%%%% <yates@ieee.org> % 'Eldorado Overture', *Eldorado*, ELO >>http://www.digitalsignallabs.com >> > > Hi, thank you for your reply. As I outlined earlier I'd like to work in > audio area. Also some specifics: ADC is not required on the board, 4 or 5 > ch DAC (96 or 192 kHz). Not sure about the speed, I guess most DSPs can > handle simple filtering of 5 ch in real time. > So you advise for 55xx series board. As I see this is low power fixed > point dsp. What is better for high quality real time audio processing > fixed or floating point? > Also this is low power chip, I don't think it's critical in my case, are > there any trade-offs related to low power consumtion? > The only 55xx kit I was able to find on TI's site is 5509 one, and it > doesn't seem to have 5 output channels (DACs)... However 24 bit is good. > Is there any specific kit you have in mind for my application?You're right that the 55x is lowpower and not really well-suited for high-quality audio. It is often used in the audio chain for cellphones and, I think in some cases, hearing aids, so it does have a role in the audio field - just a certain specific part. I should also mention that Ceva is a player in this field with (have they updated this?) the Oak/Teak families of DSPs. If you're interested in multi-channel, high-quality audio, I suspect the Freescale line is the way to go. Somebody back me up (or correct me). I don't have experience with Freescale so I can't quote EVM kits, etc., but that's the direction I'd go. The choice of data format (fixed-point or floating-point) is not orthogonal to processor choice but actually very dependent on it. However, if you had freedom to choose, there's not an obvious choice. My preference, for high-quality, high resolution audio, would be for fixed-point since you can more explicitly control the (re)quantization on such machines. -- % Randy Yates % "I met someone who looks alot like you, %% Fuquay-Varina, NC % she does the things you do, %%% 919-577-9882 % but she is an IBM." %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://www.digitalsignallabs.com
Reply by ●November 5, 20072007-11-05
Randy Yates <yates@ieee.org> wrote in news:m3sl3lai13.fsf@ieee.org:> "Decay" <dan_nomad@mail.ru> writes: > >>> >>>I suggest that you first identify the application area that you'd >>>like to work in. Broadly, those could be: audio, communications, or >>>video. I would then look for starter kits from the following based on >>>area: >>> >>> audio: Freescale, TI 55x >>> communications TI 55x, 64x >>> video: TI 64x, DaVinci. >>> >>>-- >>>% Randy Yates % "The dreamer, the unwoken fool - >>>%% Fuquay-Varina, NC % in dreams, no pain will kiss the >> brow..." >>>%%% 919-577-9882 % >>>%%%% <yates@ieee.org> % 'Eldorado Overture', *Eldorado*, >>>ELO http://www.digitalsignallabs.com >>> >> >> Hi, thank you for your reply. As I outlined earlier I'd like to work >> in audio area. Also some specifics: ADC is not required on the board, >> 4 or 5 ch DAC (96 or 192 kHz). Not sure about the speed, I guess most >> DSPs can handle simple filtering of 5 ch in real time. >> So you advise for 55xx series board. As I see this is low power fixed >> point dsp. What is better for high quality real time audio processing >> fixed or floating point? >> Also this is low power chip, I don't think it's critical in my case, >> are there any trade-offs related to low power consumtion? >> The only 55xx kit I was able to find on TI's site is 5509 one, and it >> doesn't seem to have 5 output channels (DACs)... However 24 bit is >> good. Is there any specific kit you have in mind for my application? > > You're right that the 55x is lowpower and not really well-suited for > high-quality audio. It is often used in the audio chain for cellphones > and, I think in some cases, hearing aids, so it does have a role in > the audio field - just a certain specific part. I should also mention > that Ceva is a player in this field with (have they updated this?) the > Oak/Teak families of DSPs. > > If you're interested in multi-channel, high-quality audio, I suspect > the Freescale line is the way to go. Somebody back me up (or correct > me). I don't have experience with Freescale so I can't quote EVM kits, > etc., but that's the direction I'd go. > > The choice of data format (fixed-point or floating-point) is not > orthogonal to processor choice but actually very dependent on > it. However, if you had freedom to choose, there's not an obvious > choice. My preference, for high-quality, high resolution audio, would > be for fixed-point since you can more explicitly control the > (re)quantization on such machines.Randy, Randy, Randy..... Analog Devices has the largest market share in the audio space (discounting telephony & cell phones) and you didn't even mention them. ADI's SHARC dethroned the Motorola (now Freescale) 56K family at least 5 years ago. Blackfin is increasingly popular for low power audio targets. The SHARC is both a 32 bit fixed point and 32/40 bit floating point DSP. It works very well for audio. I would suggest an ADI 21369 EZ-KIT or one of our systems with an appropriate I/O board. We include the EZ-KIT debugger on our development boards so you don't need to buy a full tool set (it puts our boards on an equal footing with the manufacturers dev boards). Al Clark Danville Signal Processing, Inc.
Al Clark <aclark@danvillesignal.com> writes:> Randy, Randy, Randy..... > > Analog Devices has the largest market share in the audio space > (discounting telephony & cell phones) and you didn't even mention them. > ADI's SHARC dethroned the Motorola (now Freescale) 56K family at least 5 > years ago. Blackfin is increasingly popular for low power audio targets. > > The SHARC is both a 32 bit fixed point and 32/40 bit floating point DSP. > It works very well for audio. I would suggest an ADI 21369 EZ-KIT or one > of our systems with an appropriate I/O board. We include the EZ-KIT > debugger on our development boards so you don't need to buy a full tool > set (it puts our boards on an equal footing with the manufacturers dev > boards).Doh! Thanks for the correction, Al. To the OP: Sorry for the mis-direct. I think I'm getting old. I forgot about the SHARC's 32-bit fixed-point multiply with 80-bit accumulator. Yes, that is a NICE setup for high-resolution audio processing (if power/space isn't an issue)! -- % Randy Yates % "Ticket to the moon, flight leaves here today %% Fuquay-Varina, NC % from Satellite 2" %%% 919-577-9882 % 'Ticket To The Moon' %%%% <yates@ieee.org> % *Time*, Electric Light Orchestra http://www.digitalsignallabs.com
On Nov 4, 5:12 am, "Decay" <dan_no...@mail.ru> wrote:> Sorry for bothering you with the question that you probably heard a hundred > times... > > I'm new to DSPs and would like to buy a DSP starter kit to learn. I'd like > to have some practical results from this work, so I aim to develop an audio > processing unit taking stereo audio signal from CD, upsampling it, applying > some filters and putting it out through high sample rate DACs (192 kHz, 5 > channels would be better but I guess 4 will work for start). > Please help me identify not very expensive kit that would better serve my > project. > > Thanks!You could try the Avnet website (http://www.em.avnet.com/), which has a variety of eval boards for the components that Avnet distributes. A quick look revealed that they do have some SHARC eval boards which have codecs.
Reply by ●November 6, 20072007-11-06
Thanks to everyone! Looks like ADSP SHARC 21262/21364 kits are the most straightforward choice. BF533 seems to be an overkill, while other boards (like TI ones) need daughterboards to be properly selected to provide same functions...
On Nov 6, 3:38 pm, "Decay" <dan_no...@mail.ru> wrote:> Thanks to everyone! > > Looks like ADSP SHARC 21262/21364 kits are the most straightforward > choice. BF533 seems to be an overkill, while other boards (like TI ones) > need daughterboards to be properly selected to provide same functions...So the Avnet boards must have hit your price range?
>On Nov 6, 3:38 pm, "Decay" <dan_no...@mail.ru> wrote: >> Thanks to everyone! >> >> Looks like ADSP SHARC 21262/21364 kits are the most straightforward >> choice. BF533 seems to be an overkill, while other boards (like TIones)>> need daughterboards to be properly selected to provide samefunctions...> >So the Avnet boards must have hit your price range? > >Good question, thanx. Not really actually. But I now do not see any adequate alternative. With the requirements I listed all kits start at $500. Danville boards seem to provide more flexibility, and less pricing for each component, but end up in the same price, or even higher for the given configuration. For TI's, I wasn't able to find the combination of board+extensions to get a price quote for the whole. In some cases TI site bumped into "Page not found", in others - my experience wasn't enough to select appropriate HW among all the options. If anyone knows how to get good combination of board/daughter-board(s) at less than $500 - I'll appreciate any info. Thanks
