Levinson Durbin / Reflection coefficients
Started by Sebastian Gesemann May 1, 2004
Hi !
I want to learn more about different representations
of the LP coefficients (ie reflection coefficients, spectral
frequency line, and so on). How to transform between those
representations and what they actually mean.
I'm searching for an easy representation which is robust
against quantization and also allows the signal to be
losslessly coded. (It should be easy to calculate the LP
coefficients in a 100% deterministic manner using integer
arithmetic)
I would appreciate recommendations for articles/books that
focus on this topic (preferably free/online) or any other
advice.
Thanks!
Sebastian
PGP-Key-ID (long): 572B1778A4CA0707
Two common ways I know of are LAR(Log Area Ratios) and LSP(Line
spectral frequencies). I read from the Low Bitrate Speech
Communication Book by Kondoz.
Regards
Piyush
Sebastian Gesemann <isnt@valid.net> wrote in message news:<Pine.LNX.4.44.0405012202070.11370-100000@raven.cs.upb.de>...
> Hi ! > > I want to learn more about different representations > of the LP coefficients (ie reflection coefficients, spectral > frequency line, and so on). How to transform between those > representations and what they actually mean. > > I'm searching for an easy representation which is robust > against quantization and also allows the signal to be > losslessly coded. (It should be easy to calculate the LP > coefficients in a 100% deterministic manner using integer > arithmetic) > > I would appreciate recommendations for articles/books that > focus on this topic (preferably free/online) or any other > advice. > > > Thanks! > Sebastian
