Hi, I've got a problem with the implementation of LMS algorithm. I'm looking for desing a Digital beamforming antenna for my final project.Someone told me that it's better if I use LMS algorithm to calculate the weights of the array elements because I don't know how many users there are and those users are mobile users. My problem is that LMS algorithm needs to know the desired signal...I'm working with a WiMax Mobile System, an SOFDMA system of 5ms frames. I don't have time to transmit and received a training sequence since I need to calcute everything in real time and I don't have an spreading code as in the case of a CDMA system. How should I calculate the error without a reference signal?? What shoudl I use as initial value of complex weights? Thanks for your help. I REALLY NEED IT
How can I know my desired signal for LMS algorithm?
Started by ●November 12, 2007
Reply by ●November 12, 20072007-11-12
On Nov 12, 2:55 am, "scc" <sandracorr...@gmail.com> wrote:> Hi, > > I've got a problem with the implementation of LMS algorithm. I'm > looking for desing a Digital beamforming antenna for my final > project.Someone told me that it's better if I use LMS algorithm to > calculate the weights of the array elements because I don't know how many > users there are and those users are mobile users. > > My problem is that LMS algorithm needs to know the desired signal...I'm > working with a WiMax Mobile System, an SOFDMA system of 5ms frames. I don't > have time to transmit and received a training sequence since I need to > calcute everything in real time and I don't have an spreading code as in > the case of a CDMA system. How should I calculate the error without a > reference signal?? What shoudl I use as initial value of complex weights? > > Thanks for your help. I REALLY NEED ITSome of the techniques used for blind equalization might be useful. Is there a constant modulus for your signal-of-interest that you might exploit in your algorithm? If so, you may not need a training sequence. Darol Klawetter
On Nov 12, 2:55 am, "scc" <sandracorr...@gmail.com> wrote:> Hi, > > I've got a problem with the implementation of LMS algorithm. I'm > looking for desing a Digital beamforming antenna for my final > project.Someone told me that it's better if I use LMS algorithm to > calculate the weights of the array elements because I don't know how many > users there are and those users are mobile users. > > My problem is that LMS algorithm needs to know the desired signal...I'm > working with a WiMax Mobile System, an SOFDMA system of 5ms frames. I don't > have time to transmit and received a training sequence since I need to > calcute everything in real time and I don't have an spreading code as in > the case of a CDMA system. How should I calculate the error without a > reference signal?? What shoudl I use as initial value of complex weights? > > Thanks for your help. I REALLY NEED ITThere is also a related paper at http://www.ee.columbia.edu/~dpwe/LabROSA/proceeds/asilomar2003/pdffiles/papers/0507.pdf
