Dear all: Now i am working on a simulation to model Phase Noise and evaluate the distortion. In many web tutorials, the definition of phase noise is given. But who can help tell how to generate certain phase noise from AWGN and combine the phase noise with the transmitting signal? e.g. 16QAM. Many thanks.
Phase noise how to combine together with the transmitting signals
Started by ●December 27, 2007
Reply by ●December 27, 20072007-12-27
On Dec 27, 8:10 am, "raymondpsl" <raymond...@yahoo.com.sg> wrote:> Dear all: > > Now i am working on a simulation to model Phase Noise and evaluate the > distortion. > > In many web tutorials, the definition of phase noise is given. > > But who can help tell how to generate certain phase noise from AWGN and > combine the phase noise with the transmitting signal? e.g. 16QAM. > > Many thanks.I don't know what the official method is, but what I have done is build a FIR filter to match the double sided phase noise spectrum, pass white noise through it, then phase modulate the constellation with the filtered noise. Your constellation points should turn into arcs. John
Reply by ●December 28, 20072007-12-28
On Dec 27, 6:10 pm, "raymondpsl" <raymond...@yahoo.com.sg> wrote:> But who can help tell how to generate certain phase noise from AWGN and > combine the phase noise with the transmitting signal? e.g. 16QAM.Long back (2000 around), in 802.11 task group-b, Intersil engineers have proposed a phase noise model based on filtering white gaussian noise with a first order butterworth low pass filter. The ppt describing the modeling and the Matlab code can be found here Suggested Phase Noise Model for 802-11 HRb - Mark Webster, Mike Seals, Intersil, September 2000 http://grouper.ieee.org/groups/802/11/Documents/DocumentHolder/0-296.zip HTH, Krishna http://www.dsplog.com
Reply by ●December 30, 20072007-12-30
>On Dec 27, 8:10 am, "raymondpsl" <raymond...@yahoo.com.sg> wrote: >> Dear all: >> >> Now i am working on a simulation to model Phase Noise and evaluate the >> distortion. >> >> In many web tutorials, the definition of phase noise is given. >> >> But who can help tell how to generate certain phase noise from AWGNand>> combine the phase noise with the transmitting signal? e.g. 16QAM. >> >> Many thanks. > >I don't know what the official method is, but what I have done is >build a FIR filter to match the double sided phase noise spectrum, >pass white noise through it, then phase modulate the constellation >with the filtered noise. Your constellation points should turn into >arcs. > >John >Thanks a lot for your reply.. I will try your method. :-)
Reply by ●January 2, 20082008-01-02
Yes, depending on what you want to achieve with your model, a one-pole LP may do, or it may need to be more sophisticated. Generally: - generate a real-valued signal "pn" that has the desired phase noise spectrum (for example by filtering AWGN) - phase-modulate your Tx signal, meaning multiply with exp(i pn) It's probably already more accurate than needed, unless you're investigating some specialist topic. If you need to be more accurate, there are lots of details. For example, some phase noise processes may appear separately on in-phase and quadrature branch (uncorrelated), others are shared (correlated).
