On Jan 11, 6:37 pm, jim <".sjedgingN0sp"@m...@mwt.net> wrote:>... > That said, yes the DecB method will tend to have a > longer filter or in other words will tend to have more additions and > multiplications for each pixel out. So how is that going to be more > efficient? >...In a practical implementation, DecB won't have more operations because it will use the polyphase decomposition. If DecB's filter length is N * L, DecA's input bandlimit filter length is N, and the number of input samples is P, DecA will require N * P operations (ignoring cost of 2-point interpolator) and DecB will require N * P * (L / M) operations>.. > > This means the effect > > of the filter response that has been applied to the input signal also > > gets compressed by 1/L and imaged; thus, you can't simply multiply the > > two frequency responses. > > Why not? You don't seem to have any problem conceptualizing doing that > with DecB after scaling up and stuffing with zeroes.. >..OH -- you mean multiply the *compressed and imaged* input filter response by the Bartlett response.
Dumb Decimation Technique?
Started by ●January 7, 2008
Reply by ●January 11, 20082008-01-11
