Stacy wrote:>> If you want to vary the speed of more general signals, like music, try >> http://www.dspdimension.com/category/tutorial/ >> >> Steve > > > Jerry also recommended the above mention site. It seems like the buzz word > is "Time streching" rather than slow motion. At least I now know the > correct terminology in what I am trying to accomplish. Thanks. > > The phase vocoder seems to be a candidate for my design. > > "dspdimension" gives some code for pitch shifting. It is not what I > originally asked for. Nevertheless, I am currently working with it. On the > other hand, writing Time Streching code is going to be more challenging.It's the same code, with a trivial step removed. To stretch the time, you reduce the playback rate (which shifts the pitch down) then shift the pitch up to compensate. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Slow Motion Recording
Started by ●January 8, 2008
Reply by ●January 10, 20082008-01-10
