I realize this is a bit of a fuzzy question that warrants a nebulous answer, but I'm looking for orders of magnitude. In most real world communications systems, when filtering in on a band of interest, what is the typical level of attenuation of neighbouring bands? How much does this vary for different modulation schemes? The reason I ask is that I'm playing around with implementing a radio on (eventually) an FPGA and I'm curious about the tradeoff between out of band attenuation and filter complexity. I realize this will vary greatly based on my desired outcome, modulation, etc. but what is the ballpark that I should be looking at. Right now I'm just looking at audio AM/FM, but I think I can generalize this to various digital modulations. 20dB, 40dB, 60dB? For a neighbouring radio station on the AM band? What about between channels in an 802.11 system? Does anyone have any ballpark numbers they can share? Chris
Communications - out of band suppression?
Started by ●January 10, 2008
Reply by ●January 10, 20082008-01-10
Chris Maryan wrote:> I realize this is a bit of a fuzzy question that warrants a nebulous > answer, but I'm looking for orders of magnitude. > > In most real world communications systems, when filtering in on a > band of interest, what is the typical level of attenuation of > neighbouring bands? How much does this vary for different modulation > schemes?For a receiver of the communication quality, the typical number would be at least 60dB of attenuation in the middle of the adjacent channel. For the consumer applications, somewhat 40dB suffice. You can also take a look at the performance charts of the monolite IF filters. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Some numbers from WCDMA (European 3G cellular): Noise floor in 3.84 MHz: ~ -108.1 dBm Signal: around -106 dBm (absolute power level, including other users) Interferer at 1 channel offset: -46 dBm Interferer at 2 channel offset: -46 dBm around 60 dB, allright. All the current numbers are here: http://www.3gpp.org/ftp/Specs/archive/25_series/25.101/25101-810.zip
mnentwig wrote:> Some numbers from WCDMA (European 3G cellular): > Noise floor in 3.84 MHz: ~ -108.1 dBm > Signal: around -106 dBm (absolute power level, including other users) > Interferer at 1 channel offset: -46 dBm > Interferer at 2 channel offset: -46 dBm > around 60 dB, allright. > > All the current numbers are here: > http://www.3gpp.org/ftp/Specs/archive/25_series/25.101/25101-810.zipYou seem to mix the spillage into adjacent channel in the transmitter and the adjacent channel attenuation in the receiver. VLV
> >You seem to mix the spillage into adjacent channel in the transmitter >and the adjacent channel attenuation in the receiver.Well, I was referring to the two-tone intermodulation test from table 7.9 in the 25101 document. BTW, the numbers are slightly different than what I wrote, please take from the reference in case it matters. Also, it's not necessarily the most stringent test on the filtering. Speaking about intermodulation: suppression of blockers is only part of the story. They may (as in above test) still create spurious products that fall into the wanted band... plus possible crossmodulation, phase noise mixing etc. But nonetheless, a "ballpark number" for adjacent channel rejection is a start.
>> BTW, the numbers are slightly differentActually the numbers are VERY different because the first tone in said test appears at two channel offsets, not one. Possibly not the best example for the filter, after all.
On Jan 10, 3:22 pm, "mnentwig" <mnent...@elisanet.fi> wrote:> >> BTW, the numbers are slightly different > > Actually the numbers are VERY different because the first tone in said > test appears at two channel offsets, not one. Possibly not the best > example for the filter, after all.Some applications require > 100 dB. I'm thinking of HF radio. John
On Jan 10, 12:58�pm, Chris Maryan <kmar...@gmail.com> wrote:> I realize this is a bit of a fuzzy question that warrants a nebulous > answer, but I'm looking for orders of magnitude. > > In most real �world communications systems, when filtering in on a > band of interest, what is the typical level of attenuation of > neighbouring bands? How much does this vary for different modulation > schemes? > > The reason I ask is that I'm playing around with implementing a radio > on (eventually) an FPGA and I'm curious about the tradeoff between out > of band attenuation and filter complexity. I realize this will vary > greatly based on my desired outcome, modulation, etc. but what is the > ballpark that I should be looking at. > > Right now I'm just looking at audio AM/FM, but I think I can > generalize this to various digital modulations. > > 20dB, 40dB, 60dB? For a neighbouring radio station on the AM band? > What about between channels in an 802.11 system? > > Does anyone have any ballpark numbers they can share? > > ChrisAs Vlad gave, a common value is 60dBc for the OOBE in the adjacent band, but look at DTV, now we are talking about 130dBc!!!!! by the time you are 6MHz away from the DTV band edge. I know many here will not believe this value, but yes it is true. Imagine putting a cellular uplink band adjacent to a DTV band (This may happen in the newly allocated 700MHz band) where the DTV's transmitter's OOBE will swamp the cell site receiver. Clay
On Jan 10, 10:58 pm, Chris Maryan <kmar...@gmail.com> wrote:> In most real world communications systems, when filtering in on a > band of interest, what is the typical level of attenuation of > neighbouring bands? How much does this vary for different modulation > schemes? > What about between channels in an 802.11 system? >For 802.11, the numbers specified depends on the modulation used. In (a) DSSS/CCK it is around -50dBr (b) OFDM it is around -40dBr Krishna http://www.dsplog.com
Reply by ●January 11, 20082008-01-11
On Thu, 10 Jan 2008 14:58:12 -0800 (PST), clay@claysturner.com wrote:>On Jan 10, 12:58�pm, Chris Maryan <kmar...@gmail.com> wrote: >> I realize this is a bit of a fuzzy question that warrants a nebulous >> answer, but I'm looking for orders of magnitude. >> >> In most real �world communications systems, when filtering in on a >> band of interest, what is the typical level of attenuation of >> neighbouring bands? How much does this vary for different modulation >> schemes? >> >> The reason I ask is that I'm playing around with implementing a radio >> on (eventually) an FPGA and I'm curious about the tradeoff between out >> of band attenuation and filter complexity. I realize this will vary >> greatly based on my desired outcome, modulation, etc. but what is the >> ballpark that I should be looking at. >> >> Right now I'm just looking at audio AM/FM, but I think I can >> generalize this to various digital modulations. >> >> 20dB, 40dB, 60dB? For a neighbouring radio station on the AM band? >> What about between channels in an 802.11 system? >> >> Does anyone have any ballpark numbers they can share? >> >> Chris > > >As Vlad gave, a common value is 60dBc for the OOBE in the adjacent >band, but look at DTV, now we are talking about 130dBc!!!!! by the >time you are 6MHz away from the DTV band edge. I know many here will >not believe this value, but yes it is true. Imagine putting a cellular >uplink band adjacent to a DTV band (This may happen in the newly >allocated 700MHz band) where the DTV's transmitter's OOBE will swamp >the cell site receiver. > >ClayExactly, i.e., it depends on the application. For TV-like systems where the transmit powers are extremely high the near-far problem can be pretty bad (well, extremely bad) and filtering needs to be able to handle it. But in general I wouldn't disagree with Vlad's answer in that 60dBc to 40dBc is pretty typical, also depending on how you interpret the problem. It is also possible to work from a known spec or performance requirement and sort out how good it needs to be from there. e.g., if you want a certain BER, sort out how many bits you need to get that, work backwards to the front end to assure that level of SINR all the way back to the input. Often the hardest part can be done in the analog front end with ceramic or SAW IF filters or such, which then eases the pain in the digital processing. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org
