I have a problem about TS101 ,can somebody help me?Thank you The JTAG can scaned succesfully ,but there was a error happened when I uesed JTAG to do simulation ,that is 'An EMUIR scan was attempted ,but the dsp is not ready to accept instruction via JTAG'. I don't kown what's wrong with it.
Started by ●January 13, 2008
Reply by ●January 13, 20082008-01-13
duke_winner@163.com wrote:> I have a problem about TS101 ,can somebody help me?Thank you > The JTAG can scaned succesfully ,but there was a error happened when I > uesed JTAG to do simulation ,that is 'An EMUIR scan was attempted ,but > the dsp is not ready to accept instruction via JTAG'. I don't kown > what's wrong with it.I've had this a few times using a JTAG port on a TS101 cluster. The crux of it was that the ICE and/or the TS101 board were not in a state suitable for a JTAG session. I had to power down everything, and ensure that I powered up again in the right order, and that the TS101 cluster was in a suitable reset state to start a JTAG session. 'Chops
Reply by ●January 14, 20082008-01-14
On 1��13��, ����7ʱ43��, moschops <mosc...@madasafish.com> wrote:> duke_win...@163.com wrote: > > I have a problem about TS101 ,can somebody help me?Thank you > > The JTAG can scaned succesfully ,but there was a error happened when I > > uesed JTAG to do simulation ,that is 'An EMUIR scan was attempted ,but > > the dsp is not ready to accept instruction via JTAG'. I don't kown > > what's wrong with it. > > I've had this a few times using a JTAG port on a TS101 cluster. The crux > of it was that the ICE and/or the TS101 board were not in a state > suitable for a JTAG session. > > I had to power down everything, and ensure that I powered up again in > the right order, and that the TS101 cluster was in a suitable reset > state to start a JTAG session. > > 'ChopsThank you for your help! but what's your means about 'power down everything,powered up again in the right order',how can I get a right order? Is your mean the sequence of power 1.2V and 3.3V ? or else?
duke_winner@163.com wrote:> > Thank you for your help! > but what's your means about 'power down everything,powered up again in > the right order',how can I get a right order? > Is your mean the sequence of power 1.2V and 3.3V ? or else?Unfortunately, the right order depends on exactly what you're connected to. I find that powering up the TS101 first, then the PC, and then the ICE, solved my problems. Also, I found that it was more likely to work if, after configuring my session in VDSP, I did not carry out any testsin the configurator but instead went straight to opening the session. 'Chops
Reply by ●January 15, 20082008-01-15
moschops <mosc...@madasafish.com> wrote:> Unfortunately, the right order depends on exactly what you're connected > to. I find that powering up the TS101 first, then the PC, and then the > ICE, solved my problems. > > Also, I found that it was more likely to work if, after configuring my > session in VDSP, I did not carry out any testsin the configurator but > instead went straight to opening the session. > > 'ChopsThank you very much.I'll try it with your method.Hope it can be useful. Is your meaning is that if JTAG configuretor tests successfully ,there is no trouble with TS101 itself.
