I heard that OFDM is better than CDMA in theory, e.g., from capacity point of view. And I found the following from this group by James K., which I do not fully follow though (the two equations). Especially for CDMA, where does the term 1/(1/r1+1/r2) come from? Any idea ? Thanks. Below is from James K, http://groups.google.com/group/comp.dsp/browse_thread/thread/d976778329c3af6d/36dace632b34f503?hl=en&lnk=gst&q=cdma+ofdm# `` Basically, look how much achievable capacities are different of these systems? Having assume that the # of multipath is two equal power paths, then the achievable capacities supposed to be represented as [OFDM] C_OFDM = 1/2*{Fc(r1*SNR/2)+Fc(r2*SNR/2)} [CDMA with ZF receiver] C_CDMA_ZF = Fc(q(r)*SNR/2), q(r) = ((2*r1*r2)/(r1+r2) where Fc(x) = 1/2*log(1+x), each of {r1,r2} is 2nd oder chi-square distributed random variable (2*sigma^2 = 1), and SNR is Signal-to- Noise power Ratio. Thus, as long as the external diversity is limited in the systems, the capacity of OFDM seems quite larger than that of CDMA because of its intrinsic diversity effect; on the other hand, with assumptions of high-order diversity in {r1,r2,r} and high SNR, C_OFDM ~= C_CDMA_ZF. Note that in high SNR, the capacity of CDMA_ZF approaches to that of CDMA with MMSE receiver, which is the optimal linear receiver. For further study, we need to consider the ML case. [Abbreviation] ZF: Zero-Forcing MMSE: Minimum Mean Square Error ML: Maximum Likelihood
Why OFDM is better than CDMA in theory?
Started by ●January 17, 2008
Reply by ●January 17, 20082008-01-17
"phil" <philgo@gmail.com> wrote in message news:86d28d10-277c-4a7a-9d5c-faa958884690@m34g2000hsf.googlegroups.com...> > I heard that OFDM is better than CDMA in theory, e.g., from capacity > point of view.I heard that RS-232 is worse then TCP/IP... How do you compare a modulation and a communication protocol? If you meant a comparison of the single carrier to multicarrier, they are equivalent. The advantage of OFDM is a simple symbol-by-symbol receiver with O(N) complexity, whereas single carrier requires MLSE with the exponential complexity. VLV
vladimir sir, good answer with loads of technicality, thanks particle (filter) reddy On Jan 17, 5:56�pm, "Vladimir Vassilevsky" <antispam_bo...@hotmail.com> wrote:> "phil" <phi...@gmail.com> wrote in message > > news:86d28d10-277c-4a7a-9d5c-faa958884690@m34g2000hsf.googlegroups.com... > > > > > I heard that OFDM is better than CDMA in theory, e.g., from capacity > > point of view. > > I heard that RS-232 is worse then TCP/IP... > How do you compare a modulation and a communication protocol? > > If you meant a comparison of the single carrier to multicarrier, they are > equivalent. The advantage of OFDM is a simple symbol-by-symbol receiver with > O(N) complexity, whereas single carrier requires MLSE with the exponential > complexity. > > VLV
