Would someone be kind enough to check the argument below. I'm a bit uncomfortable with the conclusion. The equations are in LaTeX format. Some signal, f(t), is bandlimited such that we can represent it with samples every T seconds. f(t) = \sum_{n=-\infty}^{\infty} f(nT) sinc(\frac{\pi t}{T} - nT) The linearity property of the Fourier transform gives that F(w) = \sum_{n=-\infty}^{\infty} \mathcal{F}\{f(nT) sinc(\frac{\pi t}{T} - nT)\}(w) where \mathcal{F}\{g(t)\}(w) is the Fourier transform of g(t). As f(nT) is a single complex number for any n, this becomes F(w) = \sum_{n=-\infty}^{\infty} f(nT) \mathcal{F}\{sinc(\frac{\pi t}{T} - nT)\}(y) This means that the Fourier transform of a sampled signal can be perfectly reconstructed by a linear combination of rect functions. I feel this conclusion is wrong. Is it? And if so, why?
Interpretation of sinc interpolation in Fourier domain
Started by ●January 28, 2008
Reply by ●January 28, 20082008-01-28
On 28 Jan, 14:46, "jhealy" <johnjhe...@gmail.com> wrote:> Would someone be kind enough to check the argument below. I'm a bit > uncomfortable with the conclusion. The equations are in LaTeX format. > > Some signal, f(t), is bandlimited such that we can represent it with > samples every T seconds. > f(t) = \sum_{n=-\infty}^{\infty} f(nT) sinc(\frac{\pi t}{T} - nT) > > The linearity property of the Fourier transform gives that > > F(w) = \sum_{n=-\infty}^{\infty} \mathcal{F}\{f(nT) sinc(\frac{\pi t}{T} - > nT)\}(w) > > where \mathcal{F}\{g(t)\}(w) is the Fourier transform of g(t).Don't know how well the arguments fit till here...> As f(nT) is a single complex number for any n, this becomes > > F(w) = \sum_{n=-\infty}^{\infty} f(nT) \mathcal{F}\{sinc(\frac{\pi t}{T} - > nT)\}(y) > > This means that the Fourier transform of a sampled signal can be perfectly > reconstructed by a linear combination of rect functions. > > I feel this conclusion is wrong. Is it? And if so, why?The argument is wrong. The trick is to see that for each time t =nT there is exactly one sinc function which is nonzero. The sincs are lined up such that the top of one occurs at a time where *all* the others are zero. at those times there is only one non-zero term in the reconstruction sum. Rune
On 28 Jan., 14:46, "jhealy" <johnjhe...@gmail.com> wrote:> Would someone be kind enough to check the argument below. I'm a bit > uncomfortable with the conclusion. The equations are in LaTeX format. > > Some signal, f(t), is bandlimited such that we can represent it with > samples every T seconds. > f(t) = \sum_{n=-\infty}^{\infty} f(nT) sinc(\frac{\pi t}{T} - nT) > > The linearity property of the Fourier transform gives that > > F(w) = \sum_{n=-\infty}^{\infty} \mathcal{F}\{f(nT) sinc(\frac{\pi t}{T} - > nT)\}(w) > > where \mathcal{F}\{g(t)\}(w) is the Fourier transform of g(t). > > As f(nT) is a single complex number for any n, this becomes > > F(w) = \sum_{n=-\infty}^{\infty} f(nT) \mathcal{F}\{sinc(\frac{\pi t}{T} - > nT)\}(y) > > This means that the Fourier transform of a sampled signal can be perfectly > reconstructed by a linear combination of rect functions. > > I feel this conclusion is wrong. Is it? And if so, why?The argument is correct but the conclusion is wrong. You forgot the linear phase-shift terms exp(-i w n/T) that you get from time-shifting the sinc-kernel. So it's a linear combination of those terms exp(-i w n/T), which is just a complex Fourier series. You have just prooved that the time-domain samples are the Fourier coeffcients of the series expansion of the (periodic) spectrum. Using the injectivity of the Fourier transform, you can now argue that the samples are enough to characterize the signal - this is Whittaker's (or was it Shannon's?) original proof that the samples are enough to fully describe a bandlimited signal. Regards, Andor
>On 28 Jan., 14:46, "jhealy" <johnjhe...@gmail.com> wrote: >> Would someone be kind enough to check the argument below. I'm a bit >> uncomfortable with the conclusion. The equations are in LaTeX format. >> >> Some signal, f(t), is bandlimited such that we can represent it with >> samples every T seconds. >> f(t) = \sum_{n=-\infty}^{\infty} f(nT) sinc(\frac{\pi t}{T} - nT) >> >> The linearity property of the Fourier transform gives that >> >> F(w) = \sum_{n=-\infty}^{\infty} \mathcal{F}\{f(nT) sinc(\frac{\pit}{T} ->> nT)\}(w) >> >> where \mathcal{F}\{g(t)\}(w) is the Fourier transform of g(t). >> >> As f(nT) is a single complex number for any n, this becomes >> >> F(w) = \sum_{n=-\infty}^{\infty} f(nT) \mathcal{F}\{sinc(\frac{\pit}{T} ->> nT)\}(y) >> >> This means that the Fourier transform of a sampled signal can beperfectly>> reconstructed by a linear combination of rect functions. >> >> I feel this conclusion is wrong. Is it? And if so, why? > >The argument is correct but the conclusion is wrong. You forgot the >linear phase-shift terms exp(-i w n/T) that you get from time-shifting >the sinc-kernel. So it's a linear combination of those terms exp(-i w >n/T), which is just a complex Fourier series. > >You have just prooved that the time-domain samples are the Fourier >coeffcients of the series expansion of the (periodic) spectrum. Using >the injectivity of the Fourier transform, you can now argue that the >samples are enough to characterize the signal - this is Whittaker's >(or was it Shannon's?) original proof that the samples are enough to >fully describe a bandlimited signal. > >Regards, >Andor > > >Many thanks Andor. I hadn't forgotten about those terms, just foolishly neglected them as 'just phase'!
