Two stage interpolation : Optimum Order
Started by bharat pathak January 28, 2008
Hello Rick,
    I worked out the math and here is the solution. For two stage
    interpolation I = I1 x I2, the optimum value of I1 can be given
    by
    I1 = (fp + fs + sqrt(I*Fs*(Fs - fs - fp)))/Fs
    where various quantities are:
    fp = passband freq in hz
    fs = stopband freq in hz
    Fs = sampling freq at the input side.
    I  = overall interpolation ratio.
    For example if we take
    fp = 1khz, fs = 3khz, Fs = 8khz and I = 128 and substitute in above
    equation we get I1 = 8.5, (nearest integer value and also a value
    which is ratio of 128 is 8). Hence 1st stage interpolation should be
    by a factor of 8 and second stage interpolation should be by a factor
    0f 128/8 = 16.
    I1 = 8;
    I2 = 16;
    This will minimize the number of taps for both filters put together.
    The above equation has been arrived using Bellangers formula to
compute
    filter order. More accurate equation can be derived using Hermann
order
    equation but that procedure will be very cumbersome and might not be
    useful for hand calculations. Sometimes approximations help.
Regards
Bharat Pathak
Arithos Designs
~dsp simplified.
