Hello all, Recently, there is a tendency to use high sampling rate 96 KHz, 192 KHz in the audio application. To my knowledge, about ~ 20 KHz, everything will be cut off from the loudspeaker, amplifier, etc.. So, why 96 KHz, 192 KHz instead of 48 KHz.. Regards Arthur
What is the advantage on high-sampling rate ?
Started by ●April 21, 2004
Reply by ●April 21, 20042004-04-21
"Arthur" <arthurc99@yahoo.com> writes:> Hello all, > > Recently, there is a tendency to use high sampling rate 96 KHz, 192 KHz in > the audio application. To my knowledge, about ~ 20 KHz, everything will be > cut off from the loudspeaker, amplifier, etc.. So, why 96 KHz, 192 KHz > instead of 48 KHz..To line the pocketbooks of media and manufacturing moguls with greenery. -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
Arthur wrote:> > Hello all, > > Recently, there is a tendency to use high sampling rate 96 KHz, 192 KHz in > the audio application. To my knowledge, about ~ 20 KHz, everything will be > cut off from the loudspeaker, amplifier, etc.. So, why 96 KHz, 192 KHz > instead of 48 KHz..Analogue audio amplifers typically have a flat frequency response to 100kHz or higher. Tweeters on mid to high price range loudspeakers are also capable of reproducing frequencies well above 20kHz. There have also been double blind tests which prove that even untrained listeners can tell the difference between a 10kHz sine wave and a 10kHz square wave (components at 10kHz, 30kHz, 5okHz etc) even after the two signals have been normalised to have the same perceived volume. Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo nospam@mega-nerd.com (Yes it's valid) +-----------------------------------------------------------+ "The X-files is too optimistic. The truth is not out there." -- Anthony Ord
Hi Arthur, I think you're confusing things - everything BELOW 20 Hz will most likely be cut off. At least, this is generally done. The upper frequency limit depends on the playback gear - the 22kHz upper limit comes from the typical sampling rate being 44.1kHz. If the sample rate is higher, so is this limit. It still stands to reason whether the higher sampling rates make any sense perceptually. Personally, I'm not really convinced that they do, but why not letting people decide on their own... --smb "Arthur" <arthurc99@yahoo.com> wrote:> Hello all, > > Recently, there is a tendency to use high sampling rate 96 KHz, 192 KHz in > the audio application. To my knowledge, about ~ 20 KHz, everything will be > cut off from the loudspeaker, amplifier, etc.. So, why 96 KHz, 192 KHz > instead of 48 KHz.. > > Regards > Arthur
Hi My Friend, I don't want to get into the debate like "let people decide"... I believe that this is a Signal Processing newsgroup.. So, I would like to discuss about the Tech. or Theoretical things only. From my definition (maybe from many textbooks). I found the following : - Audible sound (20 Hz - 20 KHz) - Bat normal Ultrasound range (10 KHz - 60 KHz) - Dolphin normal Ultrasound range (7 KHz - 15 KHz) Burst (20 KHz - 170 KHz) If some comments are correct, my speaker system may well attract many BATS or DOLPHINS to come into my house. Please, I really don't want to listen the BAT/DOLPHIN to talk to each other. Regards Arthur "Stephan M. Bernsee" <stephan.bernsee@web.de> ??? news:38ab652c.0404210523.1b296f30@posting.google.com ???...> Hi Arthur, > > I think you're confusing things - everything BELOW 20 Hz will most > likely be cut off. At least, this is generally done. > > The upper frequency limit depends on the playback gear - the 22kHz > upper limit comes from the typical sampling rate being 44.1kHz. If the > sample rate is higher, so is this limit. > > It still stands to reason whether the higher sampling rates make any > sense perceptually. Personally, I'm not really convinced that they do, > but why not letting people decide on their own... > > --smb > > > > "Arthur" <arthurc99@yahoo.com> wrote: > > Hello all, > > > > Recently, there is a tendency to use high sampling rate 96 KHz, 192 KHzin> > the audio application. To my knowledge, about ~ 20 KHz, everything willbe> > cut off from the loudspeaker, amplifier, etc.. So, why 96 KHz, 192 KHz > > instead of 48 KHz.. > > > > Regards > > Arthur
Arthur wrote:> Hello all, > > Recently, there is a tendency to use high sampling rate 96 KHz, 192 KHz in > the audio application. To my knowledge, about ~ 20 KHz, everything will be > cut off from the loudspeaker, amplifier, etc.. So, why 96 KHz, 192 KHz > instead of 48 KHz..There may be a mix of technical advantages with propaganda to sell more new-and-improved equipment. Higher sampling rate may lead to easier designs with less distortion. Think of the very first CD players; some of them were reported to have noticeable distortion at high frequencies. This was presumably caused by defects in the analog filtering stage -- it was very critical, since you had to let 20kHz through with hopefully less than 3dB attenuation, but at 22.05kHz there should be an attenuation of 90dB (well, ok, let's say 60, or even 30, assuming that the best of ears could not hear that). That's a pretty tough filter to achieve with analog components that may have 1% or 0.1% tolerance (you operate the CD player at 10 degrees more than usual, and the resistors and capacitors of the output filter varied by 0.5% and your filter went crazy. Sure, then oversampling came, and you "simulate" the effect of having a high sampling rate, which simplifies the design of the reconstruction analog filter. But that does introduce a little bit of distortion -- at the very least, it makes it hard to do a *good* oversampling filter. Many other tricks have come along, but they all -- in one way or another -- simulate the effect of having a higher sampling rate, such that aliasing is easier to eliminate with simpler, stable filters. So, how about not simulating a higher sampling rate, but actually having a higher sampling rate? Given that technology now allows it, why not? (I just got a tiny 1" by 1" thing for my digital camera that holds almost twice as much information as a CD -- and there are microdrives with 2GB capacity!!!) My point is that higher sampling rates do help, although arguably they're not strictly necessary. Then again, the "more-bits-more-sampling-rate-is-better-comma-buy-the-new- and-improved-super-digital-equipment" syndrome is part of the mix. Carlos --
Stephan M. Bernsee wrote:> Hi Arthur, > > I think you're confusing things - everything BELOW 20 Hz will most > likely be cut off. At least, this is generally done. > > The upper frequency limit depends on the playback gear - the 22kHz > upper limit comes from the typical sampling rate being 44.1kHz. If the > sample rate is higher, so is this limit. > > It still stands to reason whether the higher sampling rates make any > sense perceptually. Personally, I'm not really convinced that they do, > but why not letting people decide on their own... > > --smbMany people who decide on their own end up buying centimeter-diameter gold-plated loudspeaker wire. Having spent an outrageous amount for the cables, they will inevitably hear the improvement these cables make. (Many of those same people might swear that their car's gas mileage and acceleration is improved by after-market gear-shift knobs.) http://www.homegrownaudio.com/speaker_hybrid.html asserts that while silver supply wires greatly improve sound quality, it's OK if the return wires are made of copper!?! By the way, silver is indeed a better conductor than copper, but only by a very small fraction of a wire size. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"Arthur" wrote:> > I believe that this is a Signal Processing newsgroup.. So, I would like to > discuss about the Tech. or Theoretical things only. From my definition > (maybe from many textbooks). I found the following : > - Audible sound (20 Hz - 20 KHz) > - Bat normal Ultrasound range (10 KHz - 60 KHz) > - Dolphin normal Ultrasound range (7 KHz - 15 KHz) Burst (20 KHz - 170 KHz)Yes, that sounds reasonable. Humans can in fact perceive sounds with a fundemantal frequency as low as 16Hz. Anything lower will be perceived as individual pulses.> If some comments are correct, my speaker system may well attract many BATS > or DOLPHINS to come into my house.They might indeed. That's why I said it stands to reason whether such sample rates make sense perceptually - for a human. They can make things easier on the signal processing side of things, since the aliasing problems will also be moved in areas that are inaudible. --smb
Arthur wrote:> Hi My Friend, > > I don't want to get into the debate like "let people decide"... > I believe that this is a Signal Processing newsgroup.. So, I would like to > discuss about the Tech. or Theoretical things only. From my definition > (maybe from many textbooks). I found the following : > - Audible sound (20 Hz - 20 KHz)You can not completely separate both issues. For that matter, from the purely theoretical point of view, the only answer to your original question is: "whit higher sampling rate, you get a higher limit for the maximum representable bandwidth" Pretty useless answer if it's not associated to some context; I mean, a bandwidth of 5kHz is good because it is higher than 4kHz? Is a 20Hz bandwith good? After all, it is higher than a 10Hz bandwidth. You have to put things in a certain context. And the concept of "Audible sound" (which you got wrong, BTW) is not a "purely tech. or theoretical" thing. The definition of "audible sound" is related to a human perception process that we are far from understanding in detail (we have *some* evidence of what happens up until the neuron receptors -- from there on, there is *a lot* of magic going on in our brains, with an outcome that can not even be defined from a scientific/technological point of view: a psychological sensation of sound, with all the emotional implications it might have -- a familiar voice, a pleasurable musical sound, etc.) You could restrict the context of the discussion saying that "if we assume and accept that no human can hear above 20kHz, what is the advantage of higher sampling rates?" -- but still, your point would be flawed, in that any advantage can only be an advantage when put in the context of human perception of sound. All that said, maybe my other message in this thread is closer to the kind of answer you were looking for? Still, do not ignore the fact that wanting to have a bandwidth of more than 20kHz is a valid reason, even if for 99.99% of the human population it doesn't make a difference. Carlos --
"Arthur" <arthurc99@yahoo.com> wrote in message news:c65haq$1dgf$1@news.hgc.com.hk...> Hello all, > > Recently, there is a tendency to use high sampling rate 96 KHz, 192 KHz in > the audio application. To my knowledge, about ~ 20 KHz, everything will be > cut off from the loudspeaker, amplifier, etc.. So, why 96 KHz, 192 KHz > instead of 48 KHz..Apart from the issue of audible bandwidth, having more frequency "headroom" is useful. Digital filters tend to go a bit crazy near the Nyquist frequency, so moving that frequency well above the accepted audible range is a good thing. As has been pointed out by others, frequency headroom also simplifies the analog input/output filtering stages as well as sample rate conversion. Remember that the Nyquist criteria states that it is _possible_ to perfectly reconstruct the original waveform, but not that it is _practical_ or _easy_ to do so. Increased frequency headroom generally makes it easier.
