Arthur wrote: (snip)> Thank you for all the peoples participated in the dicussion.. > The conclusion seems to be : 96 KHz + 24 bits should be enough for all > sorts of reasons. But there is a theory around stated that sampling > higher will lower down the noise floor.. Any thoughts about that..Well, increasing the number of bits per sample will do that, and there are tradeoffs between sampling rate and bits. In the early days of oversampling CD players, one reason to do it was that simpler (cheaper) D/A converters could be used with equivalent results. I believe that, as a storage medium, increasing the bits per sample is more efficient. When the CD first came out digital processing was still expensive. Note that CD's only allow 99 tracks, as the track number is stored in 8 bits BCD so that CD players don't have to do a binary to BCD conversion! -- glen
What is the advantage on high-sampling rate ?
Started by ●April 21, 2004
Reply by ●April 26, 20042004-04-26
"Bob Cain" in news:c6ff6t0oe3@enews2.newsguy.com> . . . [long original article snipped] > Max, try as I might, I can't figure out what your point is > with all this.Sorry about previous response in limited time to a question I could not immediately resolve as to seriousness, to an earlier dense post on my part. I have appreciated many of Bob Cain's past, constructive posts here. (-: Such as at least five recent and needed remonstrations about reposting a long article merely to add a short reply. :-) But I especially resonated with Bob's remark, 31 Jan 04, on technical authors who form a problem to suit a solution rather than vice-versa (if I understood that point). I have seen enough of such things in modern engineering research to believe someone could write an interesting book on it, or at least an essay; however this requires that they know many such cases, and people in that situation usually have more constructive things to do. But to give a disinterested example, a co-worker of mine some time ago was a regular co-editor of the IEEE Transactions on Signal Processing (earlier Transactions on ASSP, earlier still Transactions on Audio and Electroacoustics). This engineer had substantive background in a major application of signal processing, and complained once about a paper claiming important algorithm results, but using, he said, wholly unrealistic assumptions about the application, obvious to people with experience in it, but permitting sweeping and elegant results. (I am omitting the application area here, it does not affect the substance of the case.) Yet this paper was evidently sincere, and reflected the work of someone of skill and standing whose focus had perhaps favored publications per se over practice. When these situations arise, a gulf of intuitions or assumptions exists and it can be be hard for someone in my co-worker's position to explain the problem to someone in his author's position, who moreover is eager to see the paper in print. Back to Bob Cain's question. The first part of that long post of mine, <108lirvdplak2fd@corp.supernews.com>, answered Randy Yates's query whether papers addressing "oversampling analog-digital interfaces" that actually entailed quantization could address such interfaces as essentially a problem in filtering. (Please remember that "oversampling analog-digital interfaces" is an umbrella term I'm using that does imply different emphasis to different people, but I am using it for situations that have, or would be reasonably entail if actually used, both a "time" interface and a "value" interface, between continuous and discrete.) I referred to published writing on this situation in general. In the next paragraph I cited language ambiguities in that specialty, and the practice in some research of partitioning facets of a block that are less separate in practice. I then raised the point that analog-digital interfaces for signals, as distinct from sample-by-sample data, are more common commercially now than several years ago, illustrating with light anecdotes drawn from life. In the next, short paragraph I supported Yates's point that oversampling done to simplify analog filtering hardware is indeed a filtering issue. (It is that historical mission that flavored the tone of some DSP researchers' approach to later oversampling analog-digital interfaces that did include quantization. For example, a body of somewhat isolated literature developed that addressed such interfaces in the A/D direction as digital filters having "analog input," their term. This occupies section 9.12 in the organized bibliography within my 1991 JAES survey paper, and also appears in the review of origins of oversampling analog-digital interfaces in section 6.3 there.) My penultimate paragraph addressed a language ambiguity that is relatively recent (mostly post-1991) by pointing to the record evident in the literature, that the coinage "delta-sigma" was made to distinguish systems built around one-bit quantization, and this was the meaning of "delta-sigma" intended by writers for most of the history of that term. It mentioned in passing a theoretical advantage that contributed to special interest in one-bit quantization in monolithic oversampling data-conversion hardware (besides a basic simplicity, which had longer motivated exploration of using one-bit quantizers). This paragraph was, I concede, dense. I will add here as supplemental explanation that the people who coined the language "delta-sigma" (Inose and Yasuda), and their predecessor (Cutler) who popularized the more generic technique of multi-bit noise-shaping quantization (where the baseband content tracks the original signal), were not trying to build A/D or D/A converters in the modern sense, let alone full conversion or reconstruction chains, but rather were doing telemetry or speech or video "coding" in which they directly transmitted the high-rate oversampled noise-shaped signal derived from an analog input, then analog-lowpass-filtered it at the receiving end to recover an analog output. (This was proposed as a hardware-efficient alternative in 1954-63 to methods like FM and "full" PCM.) The mathematical basis of these techniques attracted renewed interest for the later problem of making manufacturable analog-digital interfaces, especially in the 1980s, as it became practical to make real-time specialized digital filters in monolithic form (inconceivable in the days of Cutler or Inose and Yasuda), while at the same time, analog realities for conventional high-resolution A/D -D/A conversion and sharp-cutoff filtering in monolithic form motivated searches for alternatives. (The ultimate paragraph in my posting was an offer to assist any authors unaware that using "delta-sigma" with other than one-bit quantization situations actively promotes another ambiguity formerly absent, but who seek to rationalize this usage. That is because I have extraordinary experience with such rationalizations.) So there were multiple points, and if any of them is still unclear, Bob, I may possibly be able to try further. I think that this subject naturally resists brevity and promotes density. (-: But remember, I expect responses to exceed the length of quoted text! :-) I have more on stranger-than-fiction realities in engineering literature today, but have I not said enough here in one post? Max Hauser
"Max Hauser" <maxREMOVE@THIStdl.com> writes:> [...] > Speaking of language, you probably know (but some recent authors appear not > to) that "oversampling" and "noise shaping" are wide terms in connection > with A/D conversion, while "delta-sigma" (coined and popularized by Inose et > al., 1962 -- the alternative form "sigma-delta" appeared later, about 1974) > always meant systems with specifically _one-bit_ quantization.Are you referring to: "The Subscriber-Line Circuit and the Signaling and Tone System for an Experimental Time-Division Exchange Featuring Delta-Modulation Techniques," H. INOSE et al. ? -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
Max Hauser wrote:> "Carlos Moreno" in news:uSYic.24731$2V6.341047@wagner.videotron.net... > >>Wait... Are you pulling Bob's ear and telling him "bad Bob" >>for quoting too much of your message for the little he wrote, >>or are you answering his question saying that you wrote that >>much because you had to exceed what you had quoted? >>:-) >>Carlos > > Exactly!See, I knew I had gotten it all wrong! Thanks for correcting my mistake! :-) Carlos --
Reply by ●April 27, 20042004-04-27
"Randy Yates" in news:xxp1xmawqna.fsf@usrts005.corpusers.net:> "Max Hauser" <maxREMOVE@THIStdl.com> writes: >> [...] >> ... "oversampling" and "noise shaping" are wide terms in connection >> with A/D conversion, while "delta-sigma" (coined and popularized >> by Inose et al., 1962 -- the alternative form "sigma-delta" appeared >> later, about 1974) always meant systems with specifically _one-bit_ >> quantization. > > Are you referring to: > > "The Subscriber-Line Circuit and the Signaling and Tone System for > an Experimental Time-Division Exchange Featuring Delta-Modulation > Techniques," H. INOSE et al.No, the following two papers: Inose, Yasuda, and Murakami, "A Telemetering System by Code Modulation -- Delta-Sigma Modulation," _IRE Transactions on Space Electronics and Telemetry_ vol. SET-8 pp. 204-209, September 1962. (Reprinted in N. S. Jayant's IEEE-Press reprint volume on _Waveform Quantization and Coding,_ 1976.) Inose and Yasuda, "A Unity Bit Coding Method by Negative Feedback," _Proceedings of the IEEE_ vol. 51 pp. 1524-1535, November 1963. It happens I just fetched those two references from a message I posted here on dangers of "white" quantization noise models -- on comp.dsp, message <51304@prls.UUCP>, 6 Aug 1991. The same posting also addressed the following recent separate question "Funky" in news:c6hlp9$ag9$1@newsg4.svr.pol.co.uk...> Which publication did Shannon prove the Sampling Theorem in?-- as it happens, message <51304@prls.UUCP> was an earlier screed against bizarre practices to be found in modern engineering research, with positive references, ending in reply to something else> And, of course, there is no "Nyquist theorem" (except > maybe on the Usenet) -- the honorific idiom is Nyquist rate, > and the theorem is the sampling theorem (all of this was > coined by Claude Shannon in "Communication in the > Presence of Noise," _Proceedings of the IRE_ vol. 37 > no. 1 pp. 10-21, January 1949).Two current queries answered with one 1991 posting here. How's that for promptness?
Randy Yates <yates@ieee.org> wrote:> Piergiorgio Sartor <piergiorgio.sartor@nexgo.REMOVE.THIS.de> writes: > > [...] > > independently from human perception capabilities > > Right. And we should start extending LCDs, CRTs, and other > display devices to ultraviolet - you never know what the > eye might do with those high frequencies.A certain portion of hukmans can see low ultraviolet - it needs a mechanical change that is in these cases done for unrelated to ultraviolet seeing medical reasons - but CRTs and LCDs (esp LCDs!) have a lot of other problems to be cured first before bothering with that. -- Sander +++ Out of cheese error +++
Jon Harris <goldentully@hotmail.com> wrote:> My preference would be for 64K/24-bit for storage since we really can't do much > better than 20-21 bits now and I think I've heard that thermal noise and such > will limit the ability to ever reach true 24-bit quality in real-world > ADCs/DACs. (On the other hand, true 16-bit quality was close to impossible aso we'll soon get special temprature controlled DACs on your average garden variety soundcards. Can't have precious bits go waste due to temprture fuctuations now, can we? ;-)> few decades ago...) Also, dynamic range of human hearing from threshold of > audibility to threshold of pain is somewhere close to 24-bits. I wouldn't want > to be burdened with 33% more data across the board just in case I wanted to > reproduce both a flea and the big bang in the same performance!You could probably rectify that with clever use of fp instead of integers - but is it worth it?> > But in systems where bits are plentiful and 32-bit words are more convenient, > then by all means. >-- Sander +++ Out of cheese error +++
