Hi, I'm looking at FSK modulation in matlab, using my own modulator as I don't have the matlab comms toolbox. In the time domain, the signal looks fine, but in the frequency domain, it just doesn't seem to work, I get lots of other garbage in the spectrum. I'm hoping someone can see an error in my ways... First, the time axis is 10 seconds sampled at 20Hz ie: t = 0:1/20:((200/20)-(1/20)); Next, the FSK setup, the signal has two tones: 1Hz and 4Hz. First we produce one tone for 5 seconds (corresponding to some number of digital 0 symbols in our input data stream), and then the second tone for 5 seconds (corresponding to the same number of digital 1 symbols). The FSK modulator output can be calculated using (a simplification, which shows the same problem): f = zeros(1,200); f(1:100) = 1; f(101:200) = 4; signal = sin(2*pi*f.*t); Finally, the FFT setup is 0.1Hz resolution with a maximum frequency of 10Hz, so I'm using 200 samples (as above). My inputs are a multiples of 0.1Hz to ensure the zero crossings of the sinc() response of the rectangular windowed data lie on the bin locations, so I compute the FFT and the results show lots of noise: http://picasaweb.google.co.uk/teddythornton/UntitledAlbum/photo#5184042339233679394 I'm not sure whether the problem lies with my FSK modulation scheme (although in the time domain it exactly matches what I sketch out on paper), or my FFT setup. To try and eliminate the FFT setup as the problem, I changed my input signal to two tones added together (instead of different tones at different times), ie: signal = sin(2*pi*1*t) + sin(2*pi*4*t); If I FFT this, it looks perfect - clean to -300dB: http://picasaweb.google.co.uk/teddythornton/UntitledAlbum/photo#5184042339233679410 So I think my FFT setup is OK, but the FSK modulation looks OK too, so I can't see what the problem is... Any ideas?? Thanks, Ted
FSK modulation and clean FFT
Started by ●March 31, 2008
Reply by ●March 31, 20082008-03-31
On Mar 31, 3:58 pm, Ted T <teddythorn...@googlemail.com> wrote:> Hi, > > I'm looking at FSK modulation in matlab, using my own modulator as I > don't have the matlab comms toolbox. In the time domain, the signal > looks fine, but in the frequency domain, it just doesn't seem to work, > I get lots of other garbage in the spectrum. I'm hoping someone can > see an error in my ways... > > First, the time axis is 10 seconds sampled at 20Hz ie: > > t = 0:1/20:((200/20)-(1/20)); > > Next, the FSK setup, the signal has two tones: 1Hz and 4Hz. First we > produce one tone for 5 seconds (corresponding to some number of > digital 0 symbols in our input data stream), and then the second tone > for 5 seconds (corresponding to the same number of digital 1 symbols). > The FSK modulator output can be calculated using (a simplification, > which shows the same problem): > > f = zeros(1,200); > f(1:100) = 1; > f(101:200) = 4; > signal = sin(2*pi*f.*t); > > Finally, the FFT setup is 0.1Hz resolution with a maximum frequency of > 10Hz, so I'm using 200 samples (as above). My inputs are a multiples > of 0.1Hz to ensure the zero crossings of the sinc() response of the > rectangular windowed data lie on the bin locations, so I compute the > FFT and the results show lots of noise:http://picasaweb.google.co.uk/teddythornton/UntitledAlbum/photo#51840... > > I'm not sure whether the problem lies with my FSK modulation scheme > (although in the time domain it exactly matches what I sketch out on > paper), or my FFT setup. To try and eliminate the FFT setup as the > problem, I changed my input signal to two tones added together > (instead of different tones at different times), ie: > > signal = sin(2*pi*1*t) + sin(2*pi*4*t); > > If I FFT this, it looks perfect - clean to -300dB:http://picasaweb.google.co.uk/teddythornton/UntitledAlbum/photo#51840... > > So I think my FFT setup is OK, but the FSK modulation looks OK too, so > I can't see what the problem is... Any ideas??Common FFT usage Misconception #1 The main problem is with your expectation of seeing the spectrum of an unwindowed sinusoid when taking the FFT of a rectangularly windowed sinusoid. What you are seeing isn't noise, it's the transform of your rectangular window convolved with the transform of your two sinusoids. You can see the effect of the rectangular window by zeroing either the first of second half of your data vector before doing an FFT. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
On Mon, 31 Mar 2008 15:58:18 -0700 (PDT), Ted T <teddythornton@googlemail.com> wrote:>Hi, > >I'm looking at FSK modulation in matlab, using my own modulator as I >don't have the matlab comms toolbox. In the time domain, the signal >looks fine, but in the frequency domain, it just doesn't seem to work, >I get lots of other garbage in the spectrum. I'm hoping someone can >see an error in my ways... > >First, the time axis is 10 seconds sampled at 20Hz ie: > >t = 0:1/20:((200/20)-(1/20)); > >Next, the FSK setup, the signal has two tones: 1Hz and 4Hz. First we >produce one tone for 5 seconds (corresponding to some number of >digital 0 symbols in our input data stream), and then the second tone >for 5 seconds (corresponding to the same number of digital 1 symbols). >The FSK modulator output can be calculated using (a simplification, >which shows the same problem): > >f = zeros(1,200); >f(1:100) = 1; >f(101:200) = 4; >signal = sin(2*pi*f.*t); > >Finally, the FFT setup is 0.1Hz resolution with a maximum frequency of >10Hz, so I'm using 200 samples (as above). My inputs are a multiples >of 0.1Hz to ensure the zero crossings of the sinc() response of the >rectangular windowed data lie on the bin locations, so I compute the >FFT and the results show lots of noise: >http://picasaweb.google.co.uk/teddythornton/UntitledAlbum/photo#5184042339233679394 > >I'm not sure whether the problem lies with my FSK modulation scheme >(although in the time domain it exactly matches what I sketch out on >paper), or my FFT setup. To try and eliminate the FFT setup as the >problem, I changed my input signal to two tones added together >(instead of different tones at different times), ie: > >signal = sin(2*pi*1*t) + sin(2*pi*4*t); > >If I FFT this, it looks perfect - clean to -300dB: >http://picasaweb.google.co.uk/teddythornton/UntitledAlbum/photo#5184042339233679410 > >So I think my FFT setup is OK, but the FSK modulation looks OK too, so >I can't see what the problem is... Any ideas?? > >Thanks, > >TedYes, the rectangular "window" on the symbols, i.e., the pulse shape, is causing the sidelobes you see in the first plot. I'd suggest that looking at something less than 300dB of dynamic range will be more useful as you go on, as that's about 200dB more than people typically care about. ;) In other words, even the first plot isn't looking all that bad. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org
Reply by ●April 1, 20082008-04-01
Hi Ron,> You can see the effect of the rectangular window by > zeroing either the first of second half of your data > vector before doing an FFT.Interesting, I suppose this is exactly what is shown in the first plot above, as it is just the superposition of two sinusoids which have half of their data zeroed (perhaps this is your point?). And that garbage does look like side-lobes (as Eric mentions below). In my comms book it doesn't mention anything about side lobes - just that FSK will produce two main lobes centered at f1 and f2 with width 1/To. Does this mean that FSK fundamentally produces side-lobes when analyzed with the FFT? So if I practically implemented the modulator and analyzed the output with a filterbank-based spectrum analyzer, I would see what my comms book says? I just want to make sure that my setup is correct before I start adding noise modelling to my communication channel, so that I can see the impact of the noise sources and not have the results contaminated by a poor FSK/FFT setup. Thanks for the replies, they're very helpful! Ted
Ted T wrote:> Hi Ron, > >> You can see the effect of the rectangular window by >> zeroing either the first of second half of your data >> vector before doing an FFT. > > Interesting, I suppose this is exactly what is shown in the first plot > above, as it is just the superposition of two sinusoids which have > half of their data zeroed (perhaps this is your point?). And that > garbage does look like side-lobes (as Eric mentions below). > > In my comms book it doesn't mention anything about side lobes - just > that FSK will produce two main lobes centered at f1 and f2 with width > 1/To. Does this mean that FSK fundamentally produces side-lobes when > analyzed with the FFT? So if I practically implemented the modulator > and analyzed the output with a filterbank-based spectrum analyzer, I > would see what my comms book says? > > I just want to make sure that my setup is correct before I start > adding noise modelling to my communication channel, so that I can see > the impact of the noise sources and not have the results contaminated > by a poor FSK/FFT setup. > > Thanks for the replies, they're very helpful! > > TedTry just putting a single tone into your FFT. Without windowing of the time domain data you will see a similar horrible mess of sidelobes. What you are seeing has little to do with the FSK signal you have produced. It is just artifacts of misapplying the FFT. Try applying, say, a Hamming window to the data before feeding it into the FFT. You should see those sidelobes go way down, and the real signal come into view. Steve
Hi Steve, On Apr 1, 11:06 am, Steve Underwood <ste...@dis.org> wrote:> Try just putting a single tone into your FFT.Done: t = 0:1/20:((200/20)-(1/20); signal = sin(2*pi*4*t); (ie. a 4Hz input signal) The fft of this, using the same FFT setup as previously: http://picasaweb.google.co.uk/teddythornton/UntitledAlbum/photo#5184265222266538050 Clean to -300dB, the noise floor of my simulator (Octave), I think.> Without windowing of the > time domain data you will see a similar horrible mess of sidelobes.I thought you didn't need windowing if you have a periodic signal and you have an exact integer number of cycles of your signal in your window. Sure, this is hard (impossible) to arrange for in a real system, but them I'm just calculating things in theory using matlab, so I have arranged for this. Then you are effectively applying a "rectangular" window, which has a sinc() response in the frequency domain, but the sinc() response has zero crossings at +/- 2n*pi/(tau) (n=1,2,...), where (tau) is the width (in time) of your rectangular window. So if you set your bin spacing equal to 1/(tau), the zero crossings of the sinc() function exactly match the other bin locations, and no sidelobes are observed in the output spectrum.> What > you are seeing has little to do with the FSK signal you have produced. > It is just artifacts of misapplying the FFT. Try applying, say, a > Hamming window to the data before feeding it into the FFT. You should > see those sidelobes go way down, and the real signal come into view.I tried with a hamming window and a blackman window but (surprisingly) there is absolutely no difference between either of these and the original FFT of the FSK signal, with no windowing. I could show you the graph if you like, but it is absolutely identical to the first graph in my first post above. Perhaps this is something to do with the zero crossing setup of my FFT again, meaning that the windows have no contribution to the spectrum. Thanks for your comments! Ted
On Apr 1, 6:36 am, Ted T <teddythorn...@googlemail.com> wrote:> Hi Steve, > > On Apr 1, 11:06 am, Steve Underwood <ste...@dis.org> wrote: > > > Try just putting a single tone into your FFT. > > Done: t = 0:1/20:((200/20)-(1/20); signal = sin(2*pi*4*t); > (ie. a 4Hz input signal) > > The fft of this, using the same FFT setup as previously:http://picasaweb.google.co.uk/teddythornton/UntitledAlbum/photo#51842... > > Clean to -300dB, the noise floor of my simulator (Octave), I think. > > > Without windowing of the > > time domain data you will see a similar horrible mess of sidelobes. > > I thought you didn't need windowing if you have a periodic signal and > you have an exact integer number of cycles of your signal in your > window.If a sinusoid is exactly periodic in the FFT aperture, then the signal will be bin centered. But if the length of the rectangular window on your data is not the same as that of the FFT aperture, then the main lobe will be fatter than two bin widths, and thus the side-lobes will no longer be zero.> Sure, this is hard (impossible) to arrange for in a real > system, but them I'm just calculating things in theory using matlab, > so I have arranged for this. Then you are effectively applying a > "rectangular" window, which has a sinc() response in the frequency > domain, but the sinc() response has zero crossings at +/- 2n*pi/(tau) > (n=1,2,...), where (tau) is the width (in time) of your rectangular > window. So if you set your bin spacing equal to 1/(tau), the zero > crossings of the sinc() function exactly match the other bin > locations, and no sidelobes are observed in the output spectrum. > > > What > > you are seeing has little to do with the FSK signal you have produced. > > It is just artifacts of misapplying the FFT. Try applying, say, a > > Hamming window to the data before feeding it into the FFT. You should > > see those sidelobes go way down, and the real signal come into view. > > I tried with a hamming window and a blackman window but (surprisingly) > there is absolutely no difference between either of these and the > original FFT of the FSK signal, with no windowing. I could show you > the graph if you like, but it is absolutely identical to the first > graph in my first post above. Perhaps this is something to do with the > zero crossing setup of my FFT again, meaning that the windows have no > contribution to the spectrum.The edge of the half-aperture-sized rectangular window in the middle in still visible. To reduce the "leakage" from this sharp transition (in frequency or slope), you might try separately windowing each frequency burst (a half size window in your example) and then summing, rather than summing and then windowing the full aperture. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M http://www.nicholson.com/rhn/dsp.html
On Mon, 31 Mar 2008 15:58:18 -0700, Ted T wrote:> Hi, > > I'm looking at FSK modulation in matlab, using my own modulator as I > don't have the matlab comms toolbox. In the time domain, the signal > looks fine, but in the frequency domain, it just doesn't seem to work, I > get lots of other garbage in the spectrum. I'm hoping someone can see an > error in my ways... > > First, the time axis is 10 seconds sampled at 20Hz ie: > > t = 0:1/20:((200/20)-(1/20)); > > Next, the FSK setup, the signal has two tones: 1Hz and 4Hz. First we > produce one tone for 5 seconds (corresponding to some number of digital > 0 symbols in our input data stream), and then the second tone for 5 > seconds (corresponding to the same number of digital 1 symbols). The FSK > modulator output can be calculated using (a simplification, which shows > the same problem): > > f = zeros(1,200); > f(1:100) = 1; > f(101:200) = 4; > signal = sin(2*pi*f.*t); > > Finally, the FFT setup is 0.1Hz resolution with a maximum frequency of > 10Hz, so I'm using 200 samples (as above). My inputs are a multiples of > 0.1Hz to ensure the zero crossings of the sinc() response of the > rectangular windowed data lie on the bin locations, so I compute the FFT > and the results show lots of noise: > http://picasaweb.google.co.uk/teddythornton/UntitledAlbum/photo#5184042339233679394> > I'm not sure whether the problem lies with my FSK modulation scheme > (although in the time domain it exactly matches what I sketch out on > paper), or my FFT setup. To try and eliminate the FFT setup as the > problem, I changed my input signal to two tones added together (instead > of different tones at different times), ie: > > signal = sin(2*pi*1*t) + sin(2*pi*4*t); > > If I FFT this, it looks perfect - clean to -300dB: > http://picasaweb.google.co.uk/teddythornton/UntitledAlbum/photo#5184042339233679410> > So I think my FFT setup is OK, but the FSK modulation looks OK too, so I > can't see what the problem is... Any ideas?? > > Thanks, > > TedThis is pretty much what Eric said, only worded differently: You're not holding your mouth right when you look at the first plot. What you should expect to see is a pair of sinc signals, one centered on 1Hz and one centered on 4Hz. It appears that that is, indeed, what you're seeing. As mentioned in another thread recently, what you _really_ need to do to get a spectral plot of modulated data is a _long_ string of _randomly_ modulated data, followed by some bin averaging. Better, in my mind, if you can do it, is to calculate the expected value of the autocorrelation function of your data on paper (you just can't do it experimentally) and take the Fourier transform of that. Assuming that your modulation scheme is amenable to analysis, you should only go to actual data when you start verifying your modulation software. -- Tim Wescott Control systems and communications consulting http://www.wescottdesign.com Need to learn how to apply control theory in your embedded system? "Applied Control Theory for Embedded Systems" by Tim Wescott Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
On 1 Apr, 16:11, "Ron N." <rhnlo...@yahoo.com> wrote:> The edge of the half-aperture-sized rectangular window in the > middle in still visible. To reduce the "leakage" from this > sharp transition (in frequency or slope), you might try > separately windowing each frequency burst (a half size window > in your example) and then summing, rather than summing and > then windowing the full aperture.Awesome Ron, I think I'm beginning to understand! The input consists of two 5s rectangular windows in series, so they generate sinc() functions with zero crossing points every 0.2Hz in the FFT, not every 0.1Hz as I had been assuming until now (ie. because the total data length is 10s). Because my FFT is set up for 0.1Hz bin spacings, every bin corresponding to an even multiple of 0.1Hz lies on one of the 0.2Hz zero crossing locations of the sinc (so gives no response - or a response at -300dB in my simulator), but the odd multiples of 0.1Hz don't lie on these zero crossings and so they have a response from the sinc which is much higher, at around -30dB. So I guess I could just throw away every bin which corresponds to an odd multiple of 0.1Hz - I loose half my resolution, but I then get a clean FFT. Is this the correct way to do things? I'll need to think about things a bit more before I'm completely happy, and I think I'll try the analytical autocorrelation analysis Tim mentions, but I think I now understand why the sinc function is visible in my FFT! Cheers! Ted
