I'm feeling confused. Again referring to the chart in Figure 5.2-17 on p.282 of [proakiscomm], these datapoints are for a 10^{-5} symbol error rate. Why symbol error rate? It seems like this isn't comparing apples to apples since an error in an M-bit symbol could be 1, 2, ..., or M bit errors, thus the bit error rate could be different between any two modulations. It seems like what we'd rather do is compare based on equivalent bit error rates. No? Comments? -- % Randy Yates % "Rollin' and riding and slippin' and %% Fuquay-Varina, NC % sliding, it's magic." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Living' Thing', *A New World Record*, ELO http://www.digitalsignallabs.com
Symbol Error Rate vs. Bit Error Rate?
Started by ●April 3, 2008
Reply by ●April 3, 20082008-04-03
Randy Yates <yates@ieee.org> writes:> I'm feeling confused. Again referring to the chart in Figure 5.2-17 on > p.282 of [proakiscomm], these datapoints are for a 10^{-5} symbol error > rate.@BOOK{proakiscomm, title = "{Digital Communications}", author = "John~G.~Proakis", publisher = "McGraw-Hill", edition = "fourth", year = "2001"} -- % Randy Yates % "How's life on earth? %% Fuquay-Varina, NC % ... What is it worth?" %%% 919-577-9882 % 'Mission (A World Record)', %%%% <yates@ieee.org> % *A New World Record*, ELO http://www.digitalsignallabs.com
Randy Yates <yates@ieee.org> writes:> I'm feeling confused. Again referring to the chart in Figure 5.2-17 on > p.282 of [proakiscomm], these datapoints are for a 10^{-5} symbol error > rate. > > Why symbol error rate? It seems like this isn't comparing apples to > apples since an error in an M-bit symbol could be 1, 2, ..., or M > bit errors, thus the bit error rate could be different between any > two modulations. > > It seems like what we'd rather do is compare based on equivalent > bit error rates. No? Comments?I have a similar question on Eb/N0. Why compare based on that when, at the end of the day, what we're really concerned with is transmit power? It seems like a better chart would be R/W versus transmit power for a fixed data rate and for a specified bit error rate. -- % Randy Yates % "Maybe one day I'll feel her cold embrace, %% Fuquay-Varina, NC % and kiss her interface, %%% 919-577-9882 % til then, I'll leave her alone." %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://www.digitalsignallabs.com
On Apr 3, 7:27�pm, Randy Yates <ya...@ieee.org> wrote:> Randy Yates <ya...@ieee.org> writes: > > I'm feeling confused. Again referring to the chart in Figure 5.2-17 on > > p.282 of [proakiscomm], these datapoints are for a 10^{-5} symbol error > > rate. > > > Why symbol error rate? It seems like this isn't comparing apples to > > apples since an error in an M-bit symbol could be 1, 2, ..., or M > > bit errors, thus the bit error rate could be different between any > > two modulations. > > > It seems like what we'd rather do is compare based on equivalent > > bit error rates. No? Comments? > > I have a similar question on Eb/N0. Why compare based on that when, > at the end of the day, what we're really concerned with is transmit > power? >the bottom line is the energy needed per bit transmitted compared to the noise density in the receiver and thats what Eb/No tells you.. re QPSK vs BPSK....you can think of QPSK as 2 orthogonal BPSK streams, for a given BW, you can use two BPSK transmitters (twice the power) and send twice the data rate.. so the Eb/No is the same. Mark
Reply by ●April 4, 20082008-04-04
On Thu, 03 Apr 2008 19:27:22 -0400, Randy Yates <yates@ieee.org> wrote:>Randy Yates <yates@ieee.org> writes: > >> I'm feeling confused. Again referring to the chart in Figure 5.2-17 on >> p.282 of [proakiscomm], these datapoints are for a 10^{-5} symbol error >> rate. >> >> Why symbol error rate? It seems like this isn't comparing apples to >> apples since an error in an M-bit symbol could be 1, 2, ..., or M >> bit errors, thus the bit error rate could be different between any >> two modulations. >> >> It seems like what we'd rather do is compare based on equivalent >> bit error rates. No? Comments?Sklar's text also has a very similar plot (i.e., a bandwidth-efficiency plane) in his book and he does use Pb rather than Pm, or bit error vs symbol error rate. The plots are, as one would expect, very similar. I think you'd have to ask the authors why they preferred one over the other.>I have a similar question on Eb/N0. Why compare based on that when, >at the end of the day, what we're really concerned with is transmit >power?The really nice thing about Eb/No is it makes different modulations and code rates and any mix thereof comparable for power efficiency. If the link is power limited or power is an important resource, then Eb/No is one of the more useful metrics. If throughput or spectral efficiency is also important then SNR might be a better metric. It just depends on how you're trying to manage the optimizations.>It seems like a better chart would be R/W versus transmit power for >a fixed data rate and for a specified bit error rate.That's not quite as generic since it would compare only a single data rate case, although that would be interesting for that specific comparison. Eb/No can always be converted to SNR, though, and sometimes that's useful as well. It all depends on which resource is most important: bandwidth, power, etc. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org
