On Sat, 05 Apr 2008 20:55:16 -0400, Randy Yates <yates@ieee.org> wrote:>Eric Jacobsen <eric.jacobsen@ieee.org> writes: >> [...] > >Thanks for the feedback/references Eric. > >> It's wasn't the same signal as the current standard, > >What do you mean by "current standard?"The IEEE 802.15.4a standard. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org
DSP of Wideband Signals
Started by ●April 4, 2008
Reply by ●April 6, 20082008-04-06
Randy Yates wrote:> Dave <dspguy2@netscape.net> writes: > >> On Apr 4, 8:56 am, Randy Yates <ya...@ieee.org> wrote: >>> In wideband systems such as CDMA (DSSS) and IR-UWB, the analog signal at >>> the receiver is very wide even though the datarate may be relatively >>> small. Therefore in order for demodulation and detection to be performed >>> in the digital domain, very fast ADCs and front-end DSP must be >>> utilized. In some modern IR-UWB systems, this may not be feasible due to >>> the extreme bandwidth (>1 GHz) of the signals. >>> >>> Since the underlying data rate is relatively low, much of this bandwidth >>> is "redundant" in some sense. My question is this: do techniques exist >>> in which some of the initial demodulation is performed in the analog >>> domain, the output of which is a much smaller bandwidth signal that can >>> then be more tractably (and economically!) converted and processed in >>> the digital domain? >>> >>> I'd love to hear ideas on this. >>> -- >>> % Randy Yates % "So now it's getting late, >>> %% Fuquay-Varina, NC % and those who hesitate >>> %%% 919-577-9882 % got no one..." >>> %%%% <ya...@ieee.org> % 'Waterfall', *Face The Music*, ELOhttp://www.digitalsignallabs.com >> Randy, >> While not in the communications fields, Radar systems often LFM / >> Chirp waveforms which can have a wide bandwith. To ease the ADC >> requirements Stretch processing is often performed in the analog >> domain. >> >> Instead of mixing the received signal with a constant frequency >> sinusoid it is mixed with a signal whose frequency changes linearly >> with time - usually the chirp rate matches that of the transmitted >> signal. >> >> For radar signals a target at a specific range appears as a constant >> frequency (different ranges appear at different frequencies). To >> complete the pulse compression / matched filter, you simply perform an >> FFT, and you can relate the frequency bins to particular ranges. >> >> Not sure if that helps or not - or if it was what you were looking >> for. > > All suggestions welcome and potentially useful. Thanks much for your > suggestion and your time to respond, David.In the 70s the analogue chirping and dechirping for radars was general achieved with SAW devices. I think some of the spread spectrum radios at that time may have used similar techniques. Regards, Steve
