On Apr 11, 1:32 am, Vladimir Vassilevsky <antispam_bo...@hotmail.com> wrote:> sopapo wrote: > > Hi everyone, > > > I'm working on my phd thesis in a field related with the active noise > > control and i'm looking for an algorithm with good tracking capability, to > > work with a time-varying input signal (non stastionary). > > Excuse me, but what is exactly new in your thesis ? > > By definition, there is no way to track the non-stationary signal. In > order to track the signal, you have to assume that it obeys some > stationarity. Then it is down to the classic problem of Wiener/Kalman > filter. > > > I have made several test with FXLMS, N-FXLMS, Leaky-FXLMS without much > > succes, I'm going in wrong direction with this algorithms? > > Variable-step-size-LMS could improve that tracking capability? > > *.LMS are inherently bad algorithms. They are not optimal and can't be > made optimal by the black magic manipulations. The only justification > for the *.LMS is the simplicity. > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.comActually a few years back there was a paper that proved that LMS is optimal in the sense of H infinity. K.
tracking adaptive algorithm
Started by ●April 10, 2008
Reply by ●April 10, 20082008-04-10
>>> *.LMS are inherently bad algorithms. They are not optimal and can't be >> made optimal by the black magic manipulations. The only justification >> for the *.LMS is the simplicity. >> >> Vladimir Vassilevsky >> DSP and Mixed Signal Design Consultanthttp://www.abvolt.com > >Actually a few years back there was a paper that proved that LMS is >optimal in the sense of H infinity. > >K. >Hi K., do you remember who wrote the paper? Manolis
On Apr 11, 7:16 am, "Manolis C. Tsakiris" <el01...@mail.ntua.gr> wrote:> >>> *.LMS are inherently bad algorithms. They are not optimal and can't be > >> made optimal by the black magic manipulations. The only justification > >> for the *.LMS is the simplicity. > > >> Vladimir Vassilevsky > >> DSP and Mixed Signal Design Consultanthttp://www.abvolt.com > > >Actually a few years back there was a paper that proved that LMS is > >optimal in the sense of H infinity. > > >K. > > Hi K., > > do you remember who wrote the paper? > > ManolisH({infinity} ) optimality of the LMS algorithm Hassibi, B | Sayed, A H | Kailath, T IEEE Transactions on Signal Processing. Vol. 44, no. 2, pp. 267-280. Feb. 1996 We show that the celebrated least-mean squares (LMS) adaptive algorithm is H({infinity}) optimal. The LMS algorithm has been long regarded as an approximate solution to either a stochastic or a deterministic least-squares problem, and it essentially amounts to updating the weight vector estimates along the direction of the instantaneous gradient of a quadratic cost function. We show that the LMS can be regarded as the exact solution to a minimization problem in its own right. Namely, we establish that it is a minimax filter: it minimizes the maximum energy gain from the disturbances to the predicted errors, whereas the closely related so-called normalized LMS algorithm minimizes the maximum energy gain from the disturbances to the filtered errors. Moreover, since these algorithms are central H({infinity}) filters, they minimize a certain exponential cost function and are thus also risk-sensitive optimal. We discuss the various implications of these results and show how they provide theoretical justification for the widely observed excellent robustness properties of the LMS filter K.
Reply by ●April 13, 20082008-04-13
>On Apr 10, 5:15 pm, "sopapo" <sop...@sopapo.com> wrote: >> Hi everyone, >> >> I'm working on my phd thesis in a field related with the active noise >> control and i'm looking for an algorithm with good tracking capability,to>> work with a time-varying input signal (non stastionary). >> >> I have made several test with FXLMS, N-FXLMS, Leaky-FXLMS without much >> succes, I'm going in wrong direction with this algorithms? >> Variable-step-size-LMS could improve that tracking capability? >> >> Any advice is welcomed. >> Thx. > >Submit for a Masters. > >K. >Try googling for a Wiener-Hopf adaptive algorithm? From the description, I'm not sure exactly what you're trying to do. D
