Could some DSP guru please clarify some ideas that I have ? Suppose that I am sampling some signal at some frequency fs. The sampled bytes get collected in a buffer (max buffer size is some power of 2). Let us suppose that I sample for some time and collect enough samples to completely fill up the buffer. As the sampling frequency is fs, I collect f samples per second, and so the time required to collect to all the samples in my buffer is total sample size divided by the sampling frequency. Now suppose that I am sampling some audio signal and so the the lowest audio frequency that I can capture will be the inverse of the time period calculated above. That is, if I were to compute a FFT using the sampled data, the harmonics, or peaks would correspond to the multiples of this base frequency. If so, why bother computing the FFT, since we can determine what frequencies we have captured simply by the reasoning given above, and by extension, we can capture any frequency in the audio range by varying the sampling frequency. What are the flaws in this argument ? Any hints, suggestions would be greatly appreciated, and thank you in advance for your help.
FFT related question - Please help
Started by ●April 11, 2008
Reply by ●April 11, 20082008-04-11
cpptutor2000@yahoo.com wrote: (snip)> Now suppose that I am sampling some audio signal and so the the lowest > audio frequency that I can capture will be the inverse of the time > period calculated above. That is, if I were to compute a FFT using the > sampled data, the harmonics, or peaks would correspond to the > multiples of this base frequency. If so, why bother computing the FFT, > since we can determine what frequencies we have captured simply by the > reasoning given above, and by extension, we can capture any frequency > in the audio range by varying the sampling frequency.You know the frequencies, but not the amplitude of each.> What are the flaws in this argument ? Any hints, suggestions would be > greatly appreciated, and thank you in advance for your help.Well, the FFT doesn't tell you the frequencies anyway, you have to know them already, just in the way you say. -- glen
cpptutor2000@yahoo.com wrote:> Could some DSP guru please clarify some ideas that I have ? Suppose > that I am sampling some signal at some frequency fs. The sampled bytes > get collected in a buffer (max buffer size is some power of 2). Let us > suppose that I sample for some time and collect enough samples to > completely fill up the buffer. > > As the sampling frequency is fs, I collect f samples per second, and > so the time required to collect to all the samples in my buffer is > total sample size divided by the sampling frequency. > > Now suppose that I am sampling some audio signal and so the the lowest > audio frequency that I can capture will be the inverse of the time > period calculated above. That is, if I were to compute a FFT using the > sampled data, the harmonics, or peaks would correspond to the > multiples of this base frequency. If so, why bother computing the FFT, > since we can determine what frequencies we have captured simply by the > reasoning given above, and by extension, we can capture any frequency > in the audio range by varying the sampling frequency. > > What are the flaws in this argument ? Any hints, suggestions would be > greatly appreciated, and thank you in advance for your help.What is in buffer depends on the signal. Suppose it is silence. Suppose it is a pure tone. Suppose it is a complex waveform. According to your supposition, all would have the same transform. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
